1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Including display information in NTTables
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Érico Nogueira Rolim <[email protected]>
Date: Mon, 18 Nov 2024 12:01:00 -0800
On 11/18/24 08:43, Érico Nogueira Rolim via Tech-talk wrote:
Hi again :)
I decided to split this question into a separate email, since it's
unrelated to my previous question.
With scalar and waveform PVs accessed over CA and PVA, display
information (mainly PREC for CA, and PVA has precision and form) is
transferred over the wire, allowing clients to simply use the
information provided by an IOC to best present the received data. We use
PREC extensively in our own GUIs.
However, the NTTable spec [1], group schema [2] and pvinfo output don't
include any display information. Is there some way to specify it?
Or is it a missing feature?
Yup.
[1]
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/pv-access/Normative-Types-Specification.html*nttable__;Iw!!G_uCfscf7eWS!c7DJNaU6TTajUJRrV_hQnVWQ_GkL-GybMSOGqgtDPoADRVrzUZSPuc6TdN5Y_Zc6zGjEtGVh0QURUDTti0yV4v3hg7w$
[2] https://urldefense.us/v3/__https://epics-base.github.io/pvxs/qsrv2-schema-0.json__;!!G_uCfscf7eWS!c7DJNaU6TTajUJRrV_hQnVWQ_GkL-GybMSOGqgtDPoADRVrzUZSPuc6TdN5Y_Zc6zGjEtGVh0QURUDTti0yVMXUiLfU$
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Including display information in NTTables Érico Nogueira Rolim via Tech-talk
Prev: Re: ADVimba IOC boot recGblRecordError NDPluginDriver errors Rong Huang via Tech-talk
Next: Re: Using separate .json files for NTTable definitions Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Including display information in NTTables Érico Nogueira Rolim via Tech-talk
Next: Archive-engine does not have sufficient permissions to export the .xml file LONG FENG via Tech-talk
