I am writing EPICS for a QuadEM, based on designs in the distribution. The data come at 200 Hz, and my benchmarking in EPICS shows that I receive at that rate with very low jitter. Following the examples of other electrometers, I lock()
before computePositions() and callParamCallbacks(). I have observed that the lock() takes about 6 ms, which is too long for the full packet rate. Is this a normal time for the lock()? I believe I have eliminated other calls for the lock() in my code, although
a calltree shows lock()s in the callbacks.
Thank you,
Iain.
This message has been scanned for malware by Forcepoint. www.forcepoint.com
- Re: QuadEM Update rate limited by lock Mark Rivers via Tech-talk
Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Mark Rivers via Tech-talk
<2024>
2025
Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
<2024>
2025
ANJ, 20 Nov 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
