1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Aerotech Automation1 motor questions
From: John Dobbins via Tech-talk <[email protected]>
Cc: "Eric J. Edwards" <[email protected]>
Date: Thu, 5 Dec 2024 20:53:15 +0000
All,
We have a new device which includes a single axis Aerotech Automation1 motor.
I have downloaded and built
(Alma 9,  base-7.0.6, motor - current master, Automation1 - master from October )
The IOC starts up but as there is little documentation I don't know what to expect.
Ultimately, we will be controlling this motor from SPEC (from Certified Scientific Software).  We will need to
Enable/Disable Motor
Brake On/Off
Home
Put new positions
When the IOC starts up I find it reports a position. I can command a move.   Zero position seems to agree with the Automation1 software reported zero position but when I command a move the change in raw isn't what I expect.  I should mention - I am told this set-up combines two encodes to achieve higher resolution. I need to find out more about this.
Note in the motor record:  MRES and ERES both = 0.   Changing them seemed to have no effect.
RMP always equals REP and change reasonable except for the scale factor.
I see that there exists the record:
record(waveform, "$(P)ExecuteCommand")
    field(DESC, "Execute an AeroScript command")
    field(DTYP, "asynOctetWrite")
    field(FTVL, "CHAR")
    field(NELM, "256")
    field(INP,  "@asyn($(PORT),0,$(TIMEOUT=4))AUTOMATION1_C_EXECUTE_COMMAND")
Can I, for example  send the Aeroscript command "DriveBrakeOff(1)"  as a string to that record?
Any help appreciated.
Re: Aerotech Automation1 motor questions Peterson, Kevin M. via Tech-talk
Prev: EPICS Collaboration Meeting Spring 2025 - save the date Ivan Finch - STFC UKRI via Tech-talk
Next: StreamDevice waveform record reports CALC error John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Aerotech Automation1 motor questions Peterson, Kevin M. via Tech-talk
