All,
I am using StreamDevice to read into a waveform record. While it is working the waveform STAT = CALC. I have no idea what this is telling me.
AsynTrace does not report any problems.
EPICS 7.0.2, StreamDevice-2-8-9
The record in question:
record(waveform, "ID5:SCCU19:array") {
field(DTYP, "stream")
field(FTVL, "DOUBLE")
field(NELM, "18")
field(INP, "@galil.proto get_sccu_array() $(PORT)")
field(SCAN, "1 second")
field(FLNK, "ID5:SCCU19:array_event")
epics> dbpr ID5:SCCU19:array 4
ACKS: INVALID ACKT: YES APST: Always ASG :
ASP : PTR (nil) BKLNK: ELL 18 [0x1e0f870 .. 0x1e1a5f0] BKPT: 00
BPTR: PTR 0x1e2b1d0 BUSY: 0 DESC: DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DPVT: PTR 0x1e2da80
DSET: PTR 0x844f60 DTYP: stream EGU : EVNT:
FLNK: DB_LINK ID5:SCCU19:array_event FTVL: DOUBLE HASH: 0
HOPR: 0 INP : INST_IO @galil.proto get_sccu_array() MDCP_49
LCNT: 0 LOPR: 0 LSET: PTR 0x1e27c30
MLIS: ELL 0 [(nil) .. (nil)] MLOK: a0 b1 e2 01 00 00 00 00
MPST: Always NAME: ID5:SCCU19:array NELM: 18
NORD: 18 NSEV: NO_ALARM NSTA: NO_ALARM OLDSIMM: NO
PACT: 0 PHAS: 0 PINI: NO PPN : PTR (nil)
PPNR: PTR (nil) PREC: 0 PRIO: LOW PROC: 0
PUTF: 0 RARM: 0 RDES: PTR 0x1db7050 RPRO: 0
RSET: PTR 0x847020 SCAN: 1 second SDIS: CONSTANT SDLY: -1
SEVR: INVALID SIML: CONSTANT SIMM: NO SIMPVT: PTR (nil)
SIMS: NO_ALARM SIOL: CONSTANT SPVT: PTR 0x1e30430 SSCN: <nil>
STAT: CALC TIME: 2024-12-06 10:52:45.618293874 TPRO: 0
TSE : 0 TSEL: CONSTANT UDF : 0 UDFS: INVALID
VAL : PTR (nil)
The proto file
OutTerminator = CR;
InTerminator = "";
ReplyTimeout = 3000;
ReadTimeout = 100;
get_sccu_array {
separator=", ";
out "QU sccu[],0,17,1";
in "%f";
The command sccu[],0,17,1 request the elements of the array, sscu_array[], returned as a string with a comma as the separator.
:QU sccu[],0,17,1
77.7463, -131.1270, 175.9897, 96.7502, 23666.0000, 23666.0000, 23666.0000, 23666.0000, 23669.0000, 23670.0000, 23671.0000, 23671.0000, -42.7689, 0.0000, 123108:240.0000, 23670.0000, 0.0000, 0.0000
Any advice appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
