1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Process Record at ioc initialization with OPCUA module
To: LORIOT Vivien <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Dec 2024 13:19:56 +0000
Hi Vivien,
Although I have not used OPCUA, a quick glance at your record below suggests that you should try to add this line:
field(PINI, “YES”)
https://epics.anl.gov/base/R7-0/6-docs/dbCommonRecord.html
Cheers,
Yong
NSLS-2 Accelerator Controls
From: Tech-talk <[email protected]> on behalf of LORIOT Vivien via Tech-talk <[email protected]>
Date: Wednesday, December 11, 2024 at 7:12 AM
To: [email protected] <[email protected]>
Subject: TR: Process Record at ioc initialization with OPCUA module
De : LORIOT Vivien
Envoyé : mercredi 11 décembre 2024 11:48
À : '[email protected]' <[email protected]>
Objet : Process Record at ioc initialization with OPCUA module
Hi everyone,
I’m currently using the OPCUA epics module (with the open62541 librairy) to communicate with a PLC Siemens s7-1500 and I would have a question about the process of a BO record at initialization.
With OPCUA, it seems possible to process a record at the initialization with defining the option bini inside the OUT field :
So I defined it in my bo template :
But my BO are still not processing during the IOC init. It fonctionne well with the input record (AI and BI). Maybe I didn’t understand well the bini option ?
Does someone already had this problem and have a solution to propose ?
Sinceraly,
Vivien LORIOT
Ingénieur Contrôle-Commande
Laboratoire de Développement et d’Intégration des Systèmes de Contrôle
Commissariat à l’énergie atomique et aux énergies alternatives
CEA Paris-Saclay
DRF/IRFU/DIS/LDISC
Bâtiment 472 – Pièce 105
Tel : +33 1 69 08 95 17
RE: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
TR: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
Prev: TR: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
Next: Re: Process Record at ioc initialization with OPCUA module Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: Process Record at ioc initialization with OPCUA module LORIOT Vivien via Tech-talk
