1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Strange behavior with single stepping a motor with Galil controller
Date: Mon, 30 Dec 2024 19:37:15 +0000
Folks,
I am seeing a very strange behavior when execute a set of single-step motor record moves from a script.
Configuration:
  • EPICS base 7.0.7
  • EPICS motor record, R7-3-1
  • Galil DMC-4183 motor controller
  • Galil driver V4-0-02
  • Open-loop stepper motor with MRES=.00125
  • Backlash distance BDST = 0.
I have a script that repeatedly moves the motor in single steps by incrementing or decrementing the motor record RVAL field by 1.
The script writes to the RVAL field with ca_put_callback, so it returns as soon as the move is complete, and then starts the next move.
In principle these moves should be independent of the motor record VELO and ACCL fields, since it is only moving a single step.
I observe the behavior by monitoring the done moving (DMOV) field, which is 0 when the motor is moving  and 1 when a move is complete.
If I set the VELO field to 1.0 (800 steps/s) this is the camonitor result.
(base) [epics@corvette motor]$ camonitor -tc 13BMD:m29.DMOV
13BMD:m29.DMOV                 (2024-12-30 13:17:55.364647) 1
13BMD:m29.DMOV                 (2024-12-30 13:17:55.364896) 0
13BMD:m29.DMOV                 (2024-12-30 13:17:55.403801) 1
13BMD:m29.DMOV                 (2024-12-30 13:17:55.404055) 0
13BMD:m29.DMOV                 (2024-12-30 13:17:55.442796) 1
13BMD:m29.DMOV                 (2024-12-30 13:17:55.443167) 0
13BMD:m29.DMOV                 (2024-12-30 13:17:55.481823) 1
13BMD:m29.DMOV                 (2024-12-30 13:17:55.482166) 0
13BMD:m29.DMOV                 (2024-12-30 13:17:55.521032) 1
The time to go from 1(done) to 0 (moving) is less than 1 ms.  This is the time after motion done callback for the script to begin the next move.
The time to go from 0 (moving) to 1 (done) is about 40 ms.  This is the time for the driver to send Ethernet command to the controller to begin the motion, for the move to complete, and for the driver to get the completion status from the controller, and to issue the CA monitors.
These timings make sense to me.
However, if I increase the VELO field from 1.0 to 1.5 (1200 steps/s) then this is the camonitor result:
13BMD:m29.DMOV                 (2024-12-30 13:26:33.994636) 1
13BMD:m29.DMOV                 (2024-12-30 13:26:33.995166) 0
13BMD:m29.DMOV                 (2024-12-30 13:26:34.502491) 1
13BMD:m29.DMOV                 (2024-12-30 13:26:34.502939) 0
13BMD:m29.DMOV                 (2024-12-30 13:26:35.010406) 1
13BMD:m29.DMOV                 (2024-12-30 13:26:35.010706) 0
13BMD:m29.DMOV                 (2024-12-30 13:26:35.518281) 1
13BMD:m29.DMOV                 (2024-12-30 13:26:35.518503) 0
13BMD:m29.DMOV                 (2024-12-30 13:26:36.026216) 1
13BMD:m29.DMOV                 (2024-12-30 13:26:36.026736) 0
The 1 to 0 time is still less than 1 ms.
But the 0 to 1 time is now about 508 ms.  It has increased by more than a factor of 12 compared to the 40 ms when VELO=1.0.
This makes no sense to me.  Why does changing the VELO field affect the time for a single-step move?
Is this a problem with the motor record, or with the Galil driver?
RE: Strange behavior with single stepping a motor with Galil controller Mark Rivers via Tech-talk
Prev: Re: Phoebus on Windows host causes IOC crash on WSL Ralph Lange via Tech-talk
Next: Re: Phoebus on Windows host causes IOC crash on WSL Zhibang Shen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Phoebus on Windows host causes IOC crash on WSL Michael Davidsaver via Tech-talk
Next: RE: Strange behavior with single stepping a motor with Galil controller Mark Rivers via Tech-talk
