1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot.
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: LiangChih Chiang <[email protected]>, Mark Rivers <[email protected]>
Date: Fri, 3 Jan 2025 09:09:29 +0100
Hej again,
happy new year !
Thanks for reporting back and sharing your experiences.
I think that there are 2 problems/phenomenon :
a) The read back position of  "DCM:ThetaM.RBV" is flickering.
  You see this already when the IOC is running.
  Why is that ?
  Mechanics are suspected to be a contributer.
  Mechanical load, high-precision encoder ?
  Is the controller running in closed loop ?
b) The initialisation is still flaky - sometimes RBV has a value of 0.0
  I can see 3 ways to improve it:
  b1) Increase the sleep() even more, 5.0 seconds ??
  b2) Use the patched version of the motor from ESS,
      which has been improved to handle this.
      And comes with log-prints, which allow a better remote-debug
      using this log-prints
https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/motor__;!!G_uCfscf7eWS!bn419u6kHpZxbNuu8R4zzXQMivZIlCxmkxfJVLifPpIHohMe-VSdNplcFUX0yAWeO-qHffPWv19bulD-H5U$ b3) I have seen the use of an EPICS (?) hook somewhere in one
     of the motor-drivers. But after searching for hooks I still
     can not find an example here on my disk or in old emails.
Another question:
How much is the motor moving ?
/Torsten
On 2025-01-03 02:54, LiangChih Chiang wrote:
I added epicsThreadSleep(1.0) after creating motor controller and axes.
I use camonitor to trace the VAL/RBV of motor records of three axes.
I rebooted ioc nine times.
Please see the following log.
I noticed that axes Z1 and Z2 successfully restored the VAL/RBV from the controller every time.
But the behavior of axis ThetaM is strange.
Two out of nine reboots, the VAL field of ThetaM record is successfully restored.
One out of nine reboots, the VAL field of ThetaM record is set to zero.
Six out of nine reboots, the VAL field of ThetaM record is set to (previous value - 0.02).
Why -0.02?
DCM:Z1.VAL                 2025-01-02 16:28:46.483683 -0.04
DCM:Z1.RBV                 2025-01-02 16:28:46.483683 -0.0401
DCM:Z2.VAL                 2025-01-02 20:41:47.713687 0.0657
DCM:Z2.RBV                 2025-01-02 20:41:47.713687 0.0653
DCM:ThetaM.VAL             2025-01-02 16:28:50.353358 7.53376  <--
DCM:ThetaM.RBV             2025-01-02 16:28:50.353358 7.53376
ioc reboot
DCM:Z1.VAL                 2025-01-03 08:46:20.410653 -0.0401
DCM:Z1.RBV                 2025-01-03 08:46:20.410653 -0.04
DCM:Z2.VAL                 2025-01-03 08:46:20.350513 0.0653
DCM:Z2.RBV                 2025-01-03 08:46:20.350513 0.0657
DCM:ThetaM.VAL             2025-01-03 08:46:20.500699 7.53376   <-- same as previous
DCM:ThetaM.RBV             2025-01-03 08:46:20.500699 7.53376
ioc reboot
DCM:Z1.VAL                 2025-01-03 08:54:04.045355 -0.04
DCM:Z1.RBV                 2025-01-03 08:54:04.045355 -0.0401
DCM:Z2.VAL                 2025-01-03 08:54:03.985246 0.0657
DCM:Z2.RBV                 2025-01-03 08:54:03.985246 0.0653
DCM:ThetaM.VAL             2025-01-03 08:54:05.156115 7.51376   <-- different -0.02 DCM:ThetaM.RBV             2025-01-03 08:54:05.156115 7.52741   <-- motor move
DCM:ThetaM.RBV             2025-01-03 08:54:05.335235 7.52131
DCM:ThetaM.RBV             2025-01-03 08:54:05.505113 7.51621
DCM:ThetaM.RBV             2025-01-03 08:54:05.675255 7.51376
DCM:ThetaM.RBV             2025-01-03 08:54:05.845205 7.51361
DCM:ThetaM.VAL             2025-01-03 08:54:05.845205 7.51376
DCM:ThetaM.RBV             2025-01-03 08:54:05.995251 7.51356
DCM:ThetaM.RBV             2025-01-03 08:54:06.495140 7.51371
DCM:ThetaM.RBV             2025-01-03 08:54:06.795186 7.51376
DCM:ThetaM.RBV             2025-01-03 08:54:06.965241 7.51381
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:00:47.829590 -0.0401
DCM:Z1.RBV                 2025-01-03 09:00:47.829590 -0.04
DCM:Z2.VAL                 2025-01-03 09:00:47.769508 0.0653
DCM:Z2.RBV                 2025-01-03 09:00:47.769508 0.0657
DCM:ThetaM.VAL             2025-01-03 09:00:49.279478 7.49377   <-- different -0.01999 DCM:ThetaM.RBV             2025-01-03 09:00:49.279478 7.49611   <-- motor move
DCM:ThetaM.RBV             2025-01-03 09:00:49.449660 7.49371
DCM:ThetaM.RBV             2025-01-03 09:00:49.619596 7.49351
DCM:ThetaM.VAL             2025-01-03 09:00:49.619596 7.49377
DCM:ThetaM.RBV             2025-01-03 09:00:49.939543 7.49356
DCM:ThetaM.RBV             2025-01-03 09:00:50.269661 7.49376
Manually move ThetaM to 7.553761
DCM:ThetaM.VAL             2025-01-03 09:04:05.044900 7.55378
DCM:ThetaM.VAL             2025-01-03 09:04:05.045646 7.55376
DCM:ThetaM.RBV             2025-01-03 09:04:05.371519 7.49566
DCM:ThetaM.RBV             2025-01-03 09:04:05.541574 7.50071
DCM:ThetaM.RBV             2025-01-03 09:04:05.711567 7.50711
DCM:ThetaM.RBV             2025-01-03 09:04:05.881592 7.51536
DCM:ThetaM.RBV             2025-01-03 09:04:06.061484 7.52551
DCM:ThetaM.RBV             2025-01-03 09:04:06.231575 7.53506
DCM:ThetaM.RBV             2025-01-03 09:04:06.402009 7.54296
DCM:ThetaM.RBV             2025-01-03 09:04:06.571571 7.54866
DCM:ThetaM.RBV             2025-01-03 09:04:06.741529 7.55221
DCM:ThetaM.RBV             2025-01-03 09:04:06.911574 7.55296
DCM:ThetaM.VAL             2025-01-03 09:04:06.911574 7.55376
DCM:ThetaM.RBV             2025-01-03 09:04:07.071671 7.55301
DCM:ThetaM.RBV             2025-01-03 09:04:07.241982 7.55326
DCM:ThetaM.RBV             2025-01-03 09:04:07.561637 7.55381
DCM:ThetaM.RBV             2025-01-03 09:04:07.881647 7.55346
DCM:ThetaM.RBV             2025-01-03 09:04:08.211724 7.55356
DCM:ThetaM.RBV             2025-01-03 09:04:08.531501 7.55376
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:05:56.102804 -0.04
DCM:Z1.RBV                 2025-01-03 09:05:56.102804 -0.0401
DCM:Z2.VAL                 2025-01-03 09:05:56.042681 0.0657
DCM:Z2.RBV                 2025-01-03 09:05:56.042681 0.0653
DCM:ThetaM.VAL             2025-01-03 09:05:56.174482 7.55376   <-- same as previous DCM:ThetaM.RBV             2025-01-03 09:05:56.174482 7.55376   <-- but motor move
DCM:ThetaM.RBV             2025-01-03 09:05:57.012778 7.55206
DCM:ThetaM.RBV             2025-01-03 09:05:57.502889 7.54196
DCM:ThetaM.RBV             2025-01-03 09:05:57.822823 7.54366
DCM:ThetaM.RBV             2025-01-03 09:05:57.992678 7.54791
DCM:ThetaM.RBV             2025-01-03 09:05:58.162720 7.55171
DCM:ThetaM.RBV             2025-01-03 09:05:58.342759 7.55266
DCM:ThetaM.RBV             2025-01-03 09:05:58.492806 7.55271
DCM:ThetaM.RBV             2025-01-03 09:05:58.662711 7.55371
DCM:ThetaM.RBV             2025-01-03 09:05:58.962828 7.55376
DCM:ThetaM.RBV             2025-01-03 09:05:59.132771 7.55381
DCM:ThetaM.RBV             2025-01-03 09:06:02.762853 7.55386
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:09:37.385148 -0.0401
DCM:Z1.RBV                 2025-01-03 09:09:37.385148 -0.04
DCM:Z2.VAL                 2025-01-03 09:09:37.325204 0.0653
DCM:Z2.RBV                 2025-01-03 09:09:37.325204 0.0657
DCM:ThetaM.VAL             2025-01-03 09:09:38.354986 0         <-- different, zero! DCM:ThetaM.RBV             2025-01-03 09:09:38.354986 7.55181   <-- motor move
DCM:ThetaM.RBV             2025-01-03 09:09:38.535008 7.54706
DCM:ThetaM.RBV             2025-01-03 09:09:38.704917 7.54026
DCM:ThetaM.RBV             2025-01-03 09:09:38.875048 7.53131
DCM:ThetaM.RBV             2025-01-03 09:09:39.045385 7.52046
DCM:ThetaM.RBV             2025-01-03 09:09:39.215134 7.50731
DCM:ThetaM.RBV             2025-01-03 09:09:39.385166 7.49361
DCM:ThetaM.RBV             2025-01-03 09:09:39.555112 7.48036
DCM:ThetaM.RBV             2025-01-03 09:09:39.725153 7.46636
DCM:ThetaM.RBV             2025-01-03 09:09:39.894942 7.45281
DCM:ThetaM.RBV             2025-01-03 09:09:40.064989 7.43961
DCM:ThetaM.RBV             2025-01-03 09:09:40.234971 7.42526
DCM:ThetaM.RBV             2025-01-03 09:09:40.405113 7.41221
DCM:ThetaM.RBV             2025-01-03 09:09:40.585072 7.39761
DCM:ThetaM.RBV             2025-01-03 09:09:40.755044 7.38401
DCM:ThetaM.RBV             2025-01-03 09:09:40.925113 7.37066
DCM:ThetaM.RBV             2025-01-03 09:09:42.095077 7.31426
DCM:ThetaM.VAL             2025-01-03 09:09:42.095077 7.31426  <-- I stop the motor.
DCM:ThetaM.RBV             2025-01-03 09:09:46.705116 7.31421
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:12:18.906995 -0.04
DCM:Z1.RBV                 2025-01-03 09:12:18.906995 -0.0401
DCM:Z2.VAL                 2025-01-03 09:12:18.846984 0.0657
DCM:Z2.RBV                 2025-01-03 09:12:18.846984 0.0653
DCM:ThetaM.VAL             2025-01-03 09:12:21.346979 7.29431   <-- different −0.01995 DCM:ThetaM.RBV             2025-01-03 09:12:21.346979 7.29431   <-- motor move
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:18:20.230656 -0.0401
DCM:Z1.RBV                 2025-01-03 09:18:20.230656 -0.04
DCM:Z2.VAL                 2025-01-03 09:18:20.170608 0.0653
DCM:Z2.RBV                 2025-01-03 09:18:20.170608 0.0657
DCM:ThetaM.VAL             2025-01-03 09:18:20.311337 7.27437   <-- different −0.01994 DCM:ThetaM.RBV             2025-01-03 09:18:20.311337 7.29431   <-- motor move
DCM:ThetaM.RBV             2025-01-03 09:18:21.150538 7.29231
DCM:ThetaM.RBV             2025-01-03 09:18:21.320404 7.28771
DCM:ThetaM.RBV             2025-01-03 09:18:21.500407 7.28171
DCM:ThetaM.RBV             2025-01-03 09:18:21.670389 7.27681
DCM:ThetaM.RBV             2025-01-03 09:18:21.840686 7.27421
DCM:ThetaM.RBV             2025-01-03 09:18:22.010457 7.27406
DCM:ThetaM.VAL             2025-01-03 09:18:22.010457 7.27437
DCM:ThetaM.RBV             2025-01-03 09:18:22.330451 7.27421
DCM:ThetaM.RBV             2025-01-03 09:18:22.660350 7.27431
DCM:ThetaM.RBV             2025-01-03 09:18:22.960309 7.27436
DCM:ThetaM.RBV             2025-01-03 09:18:23.130896 7.27441
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:22:00.722740 -0.04
DCM:Z1.RBV                 2025-01-03 09:22:00.722740 -0.0401
DCM:Z2.VAL                 2025-01-03 09:22:00.662695 0.0657
DCM:Z2.RBV                 2025-01-03 09:22:00.662695 0.0653
DCM:ThetaM.VAL             2025-01-03 09:22:02.912859 7.25442   <-- different −0.01995 DCM:ThetaM.RBV             2025-01-03 09:22:02.912859 7.25441   <-- motor move
ioc reboot
DCM:Z1.VAL                 2025-01-03 09:33:58.400417 -0.0401
DCM:Z1.RBV                 2025-01-03 09:33:58.400417 -0.04
DCM:Z2.VAL                 2025-01-03 09:33:58.340350 0.0653
DCM:Z2.RBV                 2025-01-03 09:33:58.340350 0.0657
DCM:ThetaM.VAL             2025-01-03 09:33:59.330344 7.23447   <-- different −0.01995 DCM:ThetaM.RBV             2025-01-03 09:33:59.330344 7.25241   <-- motor move
DCM:ThetaM.RBV             2025-01-03 09:33:59.500272 7.24781
DCM:ThetaM.RBV             2025-01-03 09:33:59.680584 7.24186
DCM:ThetaM.RBV             2025-01-03 09:33:59.850291 7.23701
DCM:ThetaM.RBV             2025-01-03 09:34:00.020355 7.23431
DCM:ThetaM.RBV             2025-01-03 09:34:00.190267 7.23416
DCM:ThetaM.VAL             2025-01-03 09:34:00.190267 7.23447
DCM:ThetaM.RBV             2025-01-03 09:34:00.510337 7.23431
DCM:ThetaM.RBV             2025-01-03 09:34:00.840415 7.23441
DCM:ThetaM.RBV             2025-01-03 09:34:01.140389 7.23446
DCM:ThetaM.RBV             2025-01-03 09:34:01.310255 7.23451
On Thu, Jan 2, 2025 at 11:26 AM LiangChih Chiang <[email protected] <mailto:[email protected]>> wrote:
     >To explain a little more, it is important that the driver has
    completed the first poll cycle for the position and status of each
    axis before iocInit.
     >This is because the motor record looks at those positions during
    iocInit, and if there are non-zero it uses those values as the
    current position.
     >You can add the following to your startup script after you create
    the controller and axes to sleep for 1 second.
    I did add epicsThreadSleep(1.0).
    There are 5 motors(axis 1 to 5) connected to the motor controller.
    After epicsThreadSleep(1.0) added, it seems that the VAL/RBV of
    motor records of axis 2 to 5 can be successfully loaded back from
    the controller after IOC reboot.
    But the behavior of axis 0 (this axis is the most important) is strange.
    After IOC reboot, the motor record of axis 0 will move.
    It seems that the VAL field is set to a new value
    and I can't figure out the relationship between the new and old values.
    The axis 0 is the main axis(Bragg angle) of a double crystal
    monochromator,
    and it has corresponding pseudo motor to represent the Energy of x-
    ray beam.
    On Wed, Nov 20, 2024 at 11:04 PM Mark Rivers
        each axis before iocInit.  This is because the motor record
        looks at those positions during iocInit, and if there are non-
        zero it uses those values as the current position.  You can add
        the following to your startup script after you create the
        Let us know if this does not fix the problem.
        [email protected]>> on behalf of Torsten Bögershausen via
        Tech-talk <[email protected] <mailto:[email protected]>>
        *Sent:* Wednesday, November 20, 2024 5:15 AM
        *To:* LiangChih Chiang <[email protected]
        <mailto:[email protected]>>; [email protected]
        <mailto:[email protected]> <[email protected]
        *Subject:* Re: I implemented the Model 3 of EPICS motor driver
        reboot.
        Hej,
        without having seen ypur code, I would speculate that you run
        into a not-unknown issue using Model 3 motors, connected via
        a serial cable, USB or Ethernet?
        The value that the motorRecord needs is read from the driver,
        wich must have been able to read it from your hardware.
        Here are ESS we have a patched motor, which can handle this.
        If you use the upstream version, the easist workaround may be
        to add a sleep() after the createController() line in your st.cmd
        HTH
        /Torsten
        On 2024-11-20 09:47, LiangChih Chiang via Tech-talk wrote:
         > Hello, EPICS mates.
         > I implemented the Model 3 of EPICS motor driver support for
        some motor
         > controller,
         > but the VAL and RBV of the motor record are zero after IOC
        reboot.
         > I think the motor record doesn't restore the values of motor
        pulse and
         > encoder count from the motor controller after IOC reboot.
         > What member functions of asynMotorController and
        asynMotorAxis classes
         > should I implement?
         > Best regards.
Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Torsten Bögershausen via Tech-talk
Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
Prev: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
Next: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
