1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: calcout Record causing crash
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>, EPICS Talk <[email protected]>
Date: Fri, 10 Jan 2025 13:10:52 +0000
Hi Jörn,
It could be related to this
issue: https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/514__;!!G_uCfscf7eWS!cVpUGaKjVG3zNWwz8Vc1P6YBTB3UuiD_38PHi1Qqk8IBmc7rCZsDBsdGA8UqokFKZdFasrpf7mLLlVok65T-6eItjpk$
There are some suggestions in
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/514*issuecomment-2566654541__;Iw!!G_uCfscf7eWS!cVpUGaKjVG3zNWwz8Vc1P6YBTB3UuiD_38PHi1Qqk8IBmc7rCZsDBsdGA8UqokFKZdFasrpf7mLLlVok65T-1JXsnA4$
for how to work around it.
Cheers,
Érico
On 10/01/2025 10:03, Jörn Dreyer via Tech-talk wrote:
> Hello,
> my IOC crashes systematically whenever an calcout record gets parsed while loading.
> The error message comes from strcpy in dbStatic/dbStaticRun.c:125.ö The Message is:
> *** buffer overflow detected ***: terminated
> Im using base 7.0.8.1 on Ubuntu 24.04. It happens e.g. in devIocStats wnen loading iocAdminSoft.db for the HEARTBEAT record.
> Any clue what could be the reason for that?
> Regards,
> Jörn
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: calcout Record causing crash Jörn Dreyer via Tech-talk
Prev: calcout Record causing crash Jörn Dreyer via Tech-talk
Next: Re: calcout Record causing crash Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
