1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: calcout Record causing crash
From: Jörn Dreyer via Tech-talk <[email protected]>
To: EPICS Talk <[email protected]>
Date: Fri, 10 Jan 2025 14:15:44 +0100
Thanks Érico,
Happily its not related to this, After recompiling my IOC it magically worked.
I must have changed something on the system between compiling base and my IOC that caused this crash.
I just recompiled base and my IOC and now it works.
Jörn
Am Freitag, 10. Januar 2025, 14:10:52 Mitteleuropäische Normalzeit schrieb Érico Nogueira Rolim via Tech-talk:
> Hi Jörn,
> It could be related to this
> issue: https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/514__;!!G_uCfscf7eWS!cVpUGaKjVG3zNWwz8Vc1P6YBTB3UuiD_38PHi1Qqk8IBmc7rCZsDBsdGA8UqokFKZdFasrpf7mLLlVok65T-6eItjpk$
> There are some suggestions in
> https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/514*issuecomment-2566654541__;Iw!!G_uCfscf7eWS!cVpUGaKjVG3zNWwz8Vc1P6YBTB3UuiD_38PHi1Qqk8IBmc7rCZsDBsdGA8UqokFKZdFasrpf7mLLlVok65T-1JXsnA4$
> for how to work around it.
> Cheers,
> Érico
> On 10/01/2025 10:03, Jörn Dreyer via Tech-talk wrote:
> > Hello,
> > my IOC crashes systematically whenever an calcout record gets parsed while loading.
> > The error message comes from strcpy in dbStatic/dbStaticRun.c:125.ö The Message is:
> > *** buffer overflow detected ***: terminated
> > Im using base 7.0.8.1 on Ubuntu 24.04. It happens e.g. in devIocStats wnen loading iocAdminSoft.db for the HEARTBEAT record.
> > Any clue what could be the reason for that?
> > Regards,
> > Jörn
> Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
> Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX
Tel: +49 351 260 3263
Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
https://urldefense.us/v3/__http://www.hzdr.de__;!!G_uCfscf7eWS!bVWLtLfr9JLme_rcQhhYPmhyoZkEEhAbtP0mlLiinQ7AJJyQj7q8nujDuKoogY4FNK-OP0cuJqL-cD_CCvHOD-c$
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
calcout Record causing crash Jörn Dreyer via Tech-talk
Re: calcout Record causing crash Érico Nogueira Rolim via Tech-talk
Prev: Re: calcout Record causing crash Érico Nogueira Rolim via Tech-talk
Next: EPICS Collaboration Meeting Spring 2025 - Registration now open Jack Harper - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
