Hi, I am using motor-R7-1. In the motor submodule developed by myself, I check the status of the hard limit switch and directly set motorStatusHighLimit_ and motorStatusLowLimit_. // Read the limit status // status = pC_->readReg16(axisNo_+1, LIMIT, &read_val, DEFAULT_CONTROLLER_TIMEOUT); //low limit limit = (read_val & 0x2); setIntegerParam(pC_->motorStatusLowLimit_, limit); //high limit limit = (read_val & 0x1); setIntegerParam(pC_->motorStatusHighLimit_, limit); And I find something interesting that when the motor hits the high limit switch, and the DIR is set to Positive, the HLS will be illuminated. And if I switch the DIR to Neg, without moving the motor, the LLS will become 1 and the HLS will be 0. Is the logic intentionally designed this way, or is it because my code is not good enough? Zhibang Shen Institute of High Energy Physics, Chinese Academy of Sciences 19B Yuquan Road, Shijingshan District, Beijing, China 100049
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
