Hello Michael and Lin.
That was the reason. I've transferred the archappl.properties file from an old Archive Appliance instance and it's working.
Thanks, Eusebio.
Saludos/Best regards
University of Granada
Eusebio Naif Al-Soliman Fuentes MSc. Data Science and Computer Engineering
eunaif at correo.ugr.es
El 2025-01-26 18:16, Wang, Lin escribió:
Hello Eusebio,
I think Michael have already pointed out what the problem is, and I just want to add more info here.
According to the following links, it seems that the archappl.properties file in version 2.0.5 is missing.
https://urldefense.com/v3/__https://epics.anl.gov/tech-talk/2024/msg01220.php__;!!D9dNQwwGXtA!SAqkvp1ocezSP8PTUExS0Q3exakrIHURkELH3h6ru0RZWSLT0AsNNz9h10juVhWV83VuGxPuRqNr3Xv1efNf$
https://urldefense.com/v3/__https://epics.anl.gov/tech-talk/2024/msg01221.php__;!!D9dNQwwGXtA!SAqkvp1ocezSP8PTUExS0Q3exakrIHURkELH3h6ru0RZWSLT0AsNNz9h10juVhWV83VuGxPuRqNr3cq01Sb-$
https://urldefense.com/v3/__https://github.com/archiver-appliance/epicsarchiverap/issues/284__;!!D9dNQwwGXtA!SAqkvp1ocezSP8PTUExS0Q3exakrIHURkELH3h6ru0RZWSLT0AsNNz9h10juVhWV83VuGxPuRqNr3YAEIfBv$
Currently, there are probably two workarounds,
1. Find the archappl.properties file from source code or old installation of Archiver Appliance, and copy it into the following directoies after running single_machine_install.sh,
./engine/webapps/engine/WEB-INF/classes
./etl/webapps/etl/WEB-INF/classes
./mgmt/webapps/mgmt/WEB-INF/classes
./retrieval/webapps/retrieval/WEB-INF/classes
2. Use the following line in sampleStartup.sh to point to the property file,
export ARCHAPPL_PROPERTIES_FILENAME=/home/control/tomcat_instances/archappl.properties
Lin
-----原始邮件----- 发件人:"Eusebio Naif Al-Soliman Fuentes via Tech-talk" <tech-talk at aps.anl.gov> 发送时间:2025-01-24 21:01:49 (星期五) 收件人: "Tech Talk" <tech-talk at aps.anl.gov> 主题: Archiver Appliance 2.0.5 error 500
Hello everybody. I have installed the EPICS Archiver Appliance 2.0.5 with the single_machine_install.sh script. When I access the web interface, an error 500 appears. The complete message is the next one: Estado HTTP 500 – Internal Server Error
Tipo Informe de estado
mensaje The config service for this installation did not start up correctly. Please check the logs for any exceptions or FATAL errors. The appliance archiver cannot function without knowning the characters that separate the components of a PV name <i>org.epics.archiverappliance.config.exception.ConfigException: The appliance archiver cannot function without knowning the characters that separate the components of a PV name at org.epics.archiverappliance.config.ConvertPVNameToKey.initialize(ConvertPVNameToKey.java:82) at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:301) at org.epics.archiverappliance.config.ArchServletContextListener.contextInitialized(ArchServletContextListener.java:47) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4018) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4460) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:599) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:571) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:603) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1014) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1866) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123) at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:816) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:468) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1584) at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:312) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:109) at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:389) at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:336) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:776) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:721) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1203) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1193) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:749) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:211) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:415) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:874) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.startup.Catalina.start(Catalina.java:739) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:569) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:569) at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:234) </i>
Descripción El servidor encontró un error interno que hizo que no pudiera rellenar este requerimiento.
Apache Tomcat/9.0.98 Thanks in advance, Eusebio.
- Archiver Appliance 2.0.5 error 500 Eusebio Naif Al-Soliman Fuentes via Tech-talk
- Re: Archiver Appliance 2.0.5 error 500 Wang, Lin via Tech-talk
Re: concat multiple waveform records Jignesh J Patel via Tech-talk
Re: concat multiple waveform records Mark Rivers via Tech-talk
<2025>
Motor driver and lost TCP connection Torsten Bögershausen via Tech-talk
<2025>
ANJ, 27 Jan 2025 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
