1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: RE: concat multiple waveform records
From: Jignesh Patel via Tech-talk <tech-talk at aps.anl.gov>
To: "'Mark Rivers'" <rivers at cars.uchicago.edu>, "'Johnson, Andrew N.'" <anj at anl.gov>
Cc: tech-talk at aps.anl.gov
Date: Tue, 28 Jan 2025 10:51:19 +0530
Hi Mark,
Thanks for pointing out, its working now as expected.
Jignesh
From: Mark Rivers [mailto:rivers at cars.uchicago.edu]
Sent: 27 January 2025 19:56
To: Johnson, Andrew N. <anj at anl.gov>; Jignesh J Patel <jjp at ipr.res.in>
Subject: Re: concat multiple waveform records
Hi Jignesh,
Your acalcout record has typos.
INAA:CA_LINK SST_EFPS_THYR:CURR_WAVE0 NPP NMS
INBB:CA_LINK SST_EFPS_THYR:CURR_WAVE1 NPP NMS
The prefix starts with SST_.  But your caget has this:  SSST_EFPS_THYR:CURR_WAVE0
Your calcout record links are missing the initial "S", i.e. SST vs SSST.
That is probably why they are CA_LINKS, they are not found in the IOC.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jignesh J Patel via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, January 27, 2025 5:10 AM
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
I have tried aCalcout record to concate two arrays as per below configuration. I am not getting concated values in the acalcout record.
epics> dbpr CURR:WAVE 4
A: 0                AA: (nil)           ACKS: NO_ALARM      ACKT: YES
ADEL: 0             ALST: 0             AMASK: 0            AMEM: 8000
ASG:                ASP: (nil)          AVAL: 0x7d14b8017eb0
B: 0                BB: (nil)
BKLNK: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
BKPT: 00            C: 0                CACT: 0
CALC: CAT(AA[0,15],BB[0,15])            CC: (nil)           CLCV: 0
CSTAT: 0            D: 0                DD: (nil)           DESC: userArrayCalc
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DLYA: 0             DOPT: Use CALC      DPVT: (nil)         DSET: 0x7d16894a0940
DTYP: Soft Channel  E: 0                EE: (nil)           EGU:
EVNT:               F: 0                FF: (nil)           FLNK:CONSTANT 0
G: 0                GG: (nil)           H: 0                HH: (nil)
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             I: 0                IAAV: Ext PV NC
IBBV: Ext PV NC     ICCV: Constant      IDDV: Constant      IEEV: Constant
IFFV: Constant      IGGV: Constant      IHHV: Constant      II: (nil)
IIIV: Constant      IJJV: Constant      IKKV: Constant      ILLV: Constant
INAA:CA_LINK SST_EFPS_THYR:CURR_WAVE0 NPP NMS               INAV: Constant
INBB:CA_LINK SST_EFPS_THYR:CURR_WAVE1 NPP NMS               INBV: Constant
INCC:CONSTANT       INCV: Constant      INDD:CONSTANT       INDV: Constant
INEE:CONSTANT       INEV: Constant      INFF:CONSTANT       INFV: Constant
INGG:CONSTANT       INGV: Constant      INHH:CONSTANT       INHV: Constant
INII:CONSTANT       INIV: Constant      INJJ:CONSTANT       INJV: Constant
INKK:CONSTANT       INKV: Constant      INLL:CONSTANT       INLV: Constant
INPA:CONSTANT       INPB:CONSTANT       INPC:CONSTANT       INPD:CONSTANT
INPE:CONSTANT       INPF:CONSTANT       INPG:CONSTANT       INPH:CONSTANT
INPI:CONSTANT       INPJ:CONSTANT       INPK:CONSTANT       INPL:CONSTANT
IVOA: Continue normally                 IVOV: 0             J: 0
JJ: (nil)           K: 0                KK: (nil)           L: 0
LALM: 0             LCNT: 0             LL: (nil)           LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSET: 0x5579b3f094f0
LSV: NO_ALARM       MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: a0 14 f1 b3 79 55 00 00           MLST: 0             NAME: CURR:WAVE
NELM: 250           NEWM: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
NUSE: 0             OAV: 0x7d14b8018690 OCAL:               OCLV: 0
ODLY: 0             OEVT: 0             OOPT: On Change
ORPC: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
OUT:DB_LINK Final_wave PP NMS           OUTV: Local PV      OVAL: 0
PA: 0               PAA: (nil)          PACT: 0             PAVL: 0x7d14b801a290
PB: 0               PC: 0               PD: 0               PE: 0
PF: 0               PG: 0               PH: 0               PHAS: 0
PI: 0               PINI: NO            PJ: 0               PK: 0
PL: 0               PMEM: 8000          POAV: 0x7d14b801aa70
POVL: 0             PPN: (nil)          PPNR: (nil)         PREC: 2
PRIO: LOW           PROC: 1             PUTF: 0             PVAL: 0
RDES: 0x5579b3e2b080
RPCL: 15 02 00 00 00 00 02 0f 00 00 00 7d 16 02 00 00 00 00 02 0f
RPRO: 0             RPVT: 0x5579b3f114d0                    RSET: 0x7d16894a0880
SCAN: Passive       SDIS:CONSTANT       SEVR: NO_ALARM      SIZE: NELM
SPVT: (nil)         STAT: NO_ALARM      TIME: 2025-01-27 16:33:09.134331519
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 0
UDFS: INVALID       VAL: 0              VERS: 1.4           WAIT: NoWait
epics>
The input array WAVE0/1 values are as per below, I am trying to concate first 15 elements of both array to WAVE record.
acd@dacd-Default-string:~$ caget -a  SSST_EFPS_THYR:CURR_WAVE0
SSST_EFPS_THYR:CURR_WAVE0 2025-01-27 16:32:36.102395 125 0 0 0 0 13 27 43 56 68 78 91 100 108 114 123 126 129 127 130 127 127 127 127 129 133 129 126 126 127 129 127 127 129 130 130 127 129 132 132 130 127 134 132 134 134 136 133 133 134 132 133 139 137 137 139 136 137 136 139 137 139 140 140 142 140 143 143 140 142 143 142 143 142 145 146 146 143 143 145 146 143 146 145 148 148 145 149 148 152 148 148 150 148 150 149 150 150 152 152 150 152 152 155 153 152 152 152 153 152 152 156 156 156 156 153 155 153 155 156 158 159 156 158 159 161
dacd@dacd-Default-string:~$ caget -a  SSST_EFPS_THYR:CURR_WAVE1
SSST_EFPS_THYR:CURR_WAVE1 2025-01-27 16:32:45.854477 125 159 158 158 158 164 159 159 162 161 161 162 162 159 162 164 165 164 164 164 164 164 165 165 166 165 166 166 168 162 165 168 168 165 166 168 166 166 168 168 168 171 168 169 169 168 166 171 171 171 169 172 169 169 171 169 172 174 171 175 172 171 172 175 172 172 171 174 174 174 175 172 174 175 177 179 175 174 175 175 178 177 178 181 178 178 175 178 178 178 178 178 179 181 179 178 179 179 181 181 182 178 182 179 178 179 179 182 181 181 181 182 184 182 184 182 184 182 185 182 182 184 184 182 184 185
dacd@dacd-Default-string:~$ caget -a  CURR:WAVE.AVAL
CURR:WAVE.AVAL 2025-01-27 16:33:09.134332 250 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
My aCalcOut record is,
record(acalcout, "CURR:WAVE") {
  field(DESC, "userArrayCalc")
  field(INAA, "SST_EFPS_THYR:CURR_WAVE0")
  field(INBB, "SST_EFPS_THYR:CURR_WAVE1")
  field(PREC, "2")
  field(NELM, "250")
  field(SCAN, "Passive")
  field(CALC, "CAT(AA[0,15],BB[0,15])")
  field(OOPT, "On Change")
Please suggest the solution.
Thanks and best regards,
Jignesh
To: "jjp" <jjp at ipr.res.in>, tech-talk at aps.anl.gov
Sent: Saturday, 18 January, 2025 00:42:39
Hi Jignesh,
I haven’t used it myself, but it looks like the aynApps aCalcout record type should be able to do this, using the CAT operator, although it might not be the most efficient way. The other approach I would look at would be to write a subroutine for the aSub record type to combine your input array values into an output array — this requires you to be able to write C code.
Hope this helps, please reply to tech-talk with any follow-up questions you have.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 1/17/25, 2:13 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
I have requirement to concat multiple waveform records received from Modbus device to single waveform.
Please suggest aConcat or joinArray is suitable for this, though I have never used it.
Please guide.
Jignesh
concat multiple waveform records Jignesh Patel via Tech-talk
Re: concat multiple waveform records Johnson, Andrew N. via Tech-talk
Re: concat multiple waveform records Jignesh J Patel via Tech-talk
Re: concat multiple waveform records Mark Rivers via Tech-talk
Prev: Controls position at Sigray Richard Farnsworth via Tech-talk
Next: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: concat multiple waveform records Mark Rivers via Tech-talk
Next: Phytron support for EPICS motor (pull request #8) Lutz Rossa via Tech-talk
ANJ, 29 Jan 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
