Hi Andrew, I have tested concat record and it is working fine for our requirement to concat data buffer captured from custom Modbus interface in chunks of 125 byte. I have tried aCalcout record also which is also working fine to concat two arrays but in our case we need to concat multiple arrays due to size of data buffer. Best regards, Jignesh From: Tech-talk [mailto:tech-talk-bounces at aps.anl.gov] On Behalf Of Jignesh Patel via Tech-talk Sent: 21 January 2025 12:58 To: 'STARRITT, Andrew' <andrews at ansto.gov.au>; 'Johnson, Andrew N.' <anj at anl.gov> Cc: tech-talk at aps.anl.gov Subject: RE: concat multiple waveform records [SEC=OFFICIAL] Hi Andrew, Thanks for the link, I will explore both options concat and aCalcout. Best regards, Jignesh Hi Jignesh, You could also try the concat record, which is available here: https://github.com/AustralianSynchrotron/concat-record
Cheers Andrew Starritt Australian Synchrotron OFFICIAL | CAUTION, EXTERNAL EMAIL: This message has come from outside of ANSTO. Do not take action, click links or open attachments unless you trust the source of this message and know the content is safe. Report spam and phishing using the Report Message button or if unsure, forward this message to servicedesk at ansto.gov.au as an attachment. |
Hi Jignesh, I haven’t used it myself, but it looks like the aynApps aCalcout record type should be able to do this, using the CAT operator, although it might not be the most efficient way. The other approach I would look at would be to write a subroutine for the aSub record type to combine your input array values into an output array — this requires you to be able to write C code. Hope this helps, please reply to tech-talk with any follow-up questions you have. - Andrew Complexity comes for free, Simplicity you have to work for. Hi, I have requirement to concat multiple waveform records received from Modbus device to single waveform. Please suggest aConcat or joinArray is suitable for this, though I have never used it. Please guide. Thanks and best regards, Jignesh |
- concat multiple waveform records Jignesh Patel via Tech-talk
- Re: concat multiple waveform records Johnson, Andrew N. via Tech-talk
- RE: concat multiple waveform records [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
- RE: concat multiple waveform records [SEC=OFFICIAL] Jignesh Patel via Tech-talk
Re: MRF kernel modules not seeing hardware Michael Davidsaver via Tech-talk
Re: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
<2025>
Re: concat multiple waveform records Jignesh J Patel via Tech-talk
<2025>
ANJ, 29 Jan 2025 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
