1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Archiver Appliance - Limit on PVs
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
To: Sky Brewer <[email protected]>
Cc: [email protected]
Date: Thu, 30 Jan 2025 10:16:57 +0100
Hello Sky.
Thanks for your response. I'll try to change those parameters to have a better performance.
Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
El 2025-01-29 13:42, Sky Brewer via Tech-talk escribió:
Hi Eusebio,
You probably want to change some options in the properties file. The default file is at
https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*github.com/archiver-appliance/epicsarchiverap/blob/master/src/sitespecific/default/classpathfiles/archappl.properties__;!!G_uCfscf7eWS!ZDBlyldkC0kJvuc3n8z9xDf3skxcaYxblRVjUpIv_HUnNRqJws62_802ixxkHU8RUJ4krRt2zdYohlEI__bIr9Wl$__;Lw!!D9dNQwwGXtA!T58fUAHdAiEMGLrplweuWWKWmq25Bc1fmc7tw6rFNfbGAiJ3dRsxVoRW9f8VeXnk2jdatboKLz6Xi1xUOoqVQ0bl$
Changing each property can then have different performance impact, for instance increasing org.epics.archiverappliance.config.PVTypeInfo.sampleBufferCapacityAdjustment
Will increase the memory usage.
You probably want to increase
org.epics.archiverappliance.mgmt.MgmtRuntimeState.archivePVWorkflowBatchSize
which has a default of 1000. It’s how many PVs are acceptable to be in the intialSampling stage.
And decrease
org.epics.archiverappliance.mgmt.bpl.ArchivePVAction.minimumSamplingPeriod = 0.1
which specifies the minimumSamplingPeriod.
In some sense there is not a limit on how small this can be, it’s more how much memory you have for the Archiver Appliance to run to. If you saturate the memory, then it will start dropping events.
Hope this helps
Sky
Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
Re: Archiver Appliance - Limit on PVs Sky Brewer via Tech-talk
Prev: Re: archiver appliance and CA -> PVA Ralph Lange via Tech-talk
Next: Re: MRF kernel modules not seeing hardware Jukka Pietarinen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Archiver Appliance - Limit on PVs Sky Brewer via Tech-talk
Next: Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
