1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Archiver Appliance - Limit on PVs
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 31 Jan 2025 13:36:12 +0100
Hello everyone.
I've tried to change those parameters and also give more memory to the JVM by modifying the JAVA_OPTS variable in the sampleStartup.sh file. The performance has improved a little bit but I'm not getting the desired one.
Things get worse when I compare it to the old Archive Engine, which running on another VM of similar specifications, has better performance.
In particular, I'm running both services in two different VM but with similar specifications.
- SO: Rocky Linux 9.5.
- Number of CPUs: 4.
- RAM: 8 GB.
- Primary disk with 40 GB.
- Secondary disk with 256 GB in which "/var" is mounted.
With that, I'm able to archive 5000 sinusoidal PVs updating every 500 ms in the VM with the Archive Engine but I'm experiencing data losses with the Archiver Appliance. Also, the VM with the Archiver Appliance is getting full of memory in the root partition even though I have defined the short, medium and long term folders on the "/var" directory, which is mounted on the secondary disk.
I'm thinking that maybe the comparison is unfair with the Archiver Appliance, because the documentation describes that it's possible to deploy multiple appliances, but how can this be done? On each device in the cluster a full instance of the Archiver Appliance is deployed? Or each of the WAR Tomcats can be distributed into different devices? Because inside the appliance.xml there are fields for the IP address of each system (ETL, management, engine & retrieval).
And finally, is there a guide that describes how to perform this complex deployment?
Thanks in advance.
Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
El 2025-01-30 10:16, Eusebio Naif Al-Soliman Fuentes via Tech-talk escribió:
Hello Sky.
Thanks for your response. I'll try to change those parameters to have a better performance.
Eusebio.
[email protected]
El 2025-01-29 13:42, Sky Brewer via Tech-talk escribió:
Hi Eusebio,
You probably want to change some options in the properties file. The default file is at
https://urldefense.com/v3/__https://urldefense.us/v3/__https:/*github.com/archiver-appliance/epicsarchiverap/blob/master/src/sitespecific/default/classpathfiles/archappl.properties__;!!G_uCfscf7eWS!ZDBlyldkC0kJvuc3n8z9xDf3skxcaYxblRVjUpIv_HUnNRqJws62_802ixxkHU8RUJ4krRt2zdYohlEI__bIr9Wl$__;Lw!!D9dNQwwGXtA!T58fUAHdAiEMGLrplweuWWKWmq25Bc1fmc7tw6rFNfbGAiJ3dRsxVoRW9f8VeXnk2jdatboKLz6Xi1xUOoqVQ0bl$
Changing each property can then have different performance impact, for instance increasing org.epics.archiverappliance.config.PVTypeInfo.sampleBufferCapacityAdjustment
Will increase the memory usage.
You probably want to increase
org.epics.archiverappliance.mgmt.MgmtRuntimeState.archivePVWorkflowBatchSize
which has a default of 1000. It's how many PVs are acceptable to be in the intialSampling stage.
And decrease
org.epics.archiverappliance.mgmt.bpl.ArchivePVAction.minimumSamplingPeriod = 0.1
which specifies the minimumSamplingPeriod.
In some sense there is not a limit on how small this can be, it's more how much memory you have for the Archiver Appliance to run to. If you saturate the memory, then it will start dropping events.
Hope this helps
Sky
Re: Archiver Appliance - Limit on PVs Sky Brewer via Tech-talk
Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: Re: Understanding ASYN_CANBLOCK Marco Filho via Tech-talk
Next: RE: Re: Archiver Appliance - Limit on PVs Sky Brewer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
