Hi Evan,
Yes, two models were supported by mrfioc2 long ago. At least we found out the root cause, enjoy your PCI bus configuration troubleshooting. One time, from my experience, the PCI ID was defined in the board wrongly, Jukka did fix the board.
Thanks, Han
Hi Han,
These are cPCI-EVG-300 and cPCI-EVR-300, which “should” be supported, and indeed they are with our other CPU cards that are cooperating. They’re reporting different IDs to different hardware. At this time
I don’t think anything needs to be added, rather that there’s some hairy PCI bus configuration issue.
-Evan
[EXTERNAL] This email originated from outside of FRIB
The MRF kernel driver code defines the supported MRF cards defined in
The hardware support is the same as +5 years ago in the mrf kernel support, when I left the MTCA-verse at ESS.
So my question is now, what MRF hardwares do you use currently?
Since I don't see your PCI ID in the kernel source and my pci.ids file, we need to understand what hardware you have now.
If this is the case, we can modify the mrfioc2 kernel driver to support your hardware.
1. In most cases, mrfioc2 will work, I guess your hardware is strongly based on the MTCA MRF product lines.
2. In the worst case scenario, someone has to test the hardware and update the device support within the mrfioc2 kernel.
ESS may have the latest kernel driver for your hardware, I guess. Jerzy will confirm it.
Are the PCI IDs supposed to be intrinsic/stored on the card? The odd thing I'm seeing is that the *same* card on the same backplane has a different ID depending on which CPU I use. A known "good" CPU card and kernel module install is seeing
152, the "bad" is seeing 150.
On 1/29/25 18:52, Han Lee via Tech-talk wrote:
> FYI, The supported PCI IDs
https://github.com/epics-modules/mrfioc2/blob/master/mrmShared/linux/uio_mrf.c#L41-L74 <https ://github.com/epics-modules/mrfioc2/blob/master/mrmShared/linux/uio_mrf.c#L41-L74>
I think the essential point has already been made, when a PCI device is enumerated,
but no loaded driver associates, this is almost always the result of a PCI ID mis-match.
fyi. the 'modinfo' utility can dump the match/alias list from the meta-data stored
in a compiled kernel module.
> $ modinfo mrf.ko
> alias: pci:v000010EEd00007011sv00001A3Esd0000232Cbc*sc*i*
> alias: pci:v000010EEd00007011sv00001A3Esd0000132Cbc*sc*i*
> alias: pci:v00001A3Ed0000152Csv00001A3Esd0000152Cbc*sc*i*
> alias: pci:v00001A3Ed0000252Csv00001A3Esd0000252Cbc*sc*i*
> alias: pci:v000010EEd00007011sv00001A3Esd0000172Cbc*sc*i*
> alias: pci:v00001204d0000EC30sv00001A3Esd0000172Cbc*sc*i*
> alias: pci:v000010B5d00009056sv00001A3Esd0000192Cbc*sc*i*
> alias: pci:v000010B5d00009030sv00001A3Esd000011E6bc*sc*i*
> alias: pci:v000010B5d00009030sv00001A3Esd000020E6bc*sc*i*
> alias: pci:v000010B5d00009030sv00001A3Esd000020DCbc*sc*i*
> alias: pci:v000010B5d00009030sv00001A3Esd000010E6bc*sc*i*
These lines decode as key-value pairs with wildcards for some values.
eg. "pci:v000010B5d00009030sv00001A3Esd000010E6bc*sc*i*"
will match a PCI vendor:device 0x10ee:0x9030 sub-vendor:sub-device 0x1a3e:0x10e6
"bc*" and "sc*" match any class/sub-class
"i*" matches any interface. Although I'm not sure what "interface" means in this context.
Jeong Han Lee, Dr.rer.nat. Lawrence Berkeley National Laboratory
- Re: MRF kernel modules not seeing hardware Han Lee via Tech-talk
- Re: MRF kernel modules not seeing hardware Michael Davidsaver via Tech-talk
- Re: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
- RE: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Understanding ASYN_CANBLOCK Marco Filho via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
