1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Installation of EPICS archiver on a single Centos7 machine
From: Andrea Celentano via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 7 Feb 2025 14:50:57 +0100
Dear colleagues,
I am currently developing the slow-controls system for a small-scale experiment (~ 100 PVs), and I'd like to use the EPICS archiver to properly track them.
I am using the following setup:
* Centos7 machine (I cannot change this at the moment)
* Java JDK version 16.0.2
* Archiver release 2.0.5 (https://urldefense.us/v3/__https://github.com/archiver-appliance/epicsarchiverap/releases/tag/2.0.5__;!!G_uCfscf7eWS!dfP3pgsViV5i5uqOcqz-MWHrFko78Ypy28FydNixfzs_o8UBmRRyBJPjpqZGCwptaFyl7HX0PwxiW6n-WE7VLlepoB0sdgprJNw$ )
* Tomcat version apache-tomcat-9.0.20
* mysql connector version 5.1.21
Following the guide (https://urldefense.us/v3/__https://epicsarchiver.readthedocs.io/en/latest/sysadmin/installguide.html__;!!G_uCfscf7eWS!dfP3pgsViV5i5uqOcqz-MWHrFko78Ypy28FydNixfzs_o8UBmRRyBJPjpqZGCwptaFyl7HX0PwxiW6n-WE7VLlepoB0seOqUtEE$ ), I am using the script "single_machine_install.sh". Everything goes well, I obtain the script "sampleStartup.sh" in the folder where Tomcat Instances are located.
If I execute it, and then I open the file "mgmt/logs/catalina.err", I see the following error. and the archiver does not start.
java.sql.SQLException: Unable to load class: com.mysql.jdbc.Driver from ClassLoader:java.net.URLClassLoader@4617c264;ClassLoader:ParallelWebappClassLoader
  context: mgmt
  delegate: false
----------> Parent Classloader:
    at org.apache.tomcat.jdbc.pool.PooledConnection.connectUsingDriver(PooledConnection.java:292)     at org.apache.tomcat.jdbc.pool.PooledConnection.connect(PooledConnection.java:212)     at org.apache.tomcat.jdbc.pool.ConnectionPool.createConnection(ConnectionPool.java:744)     at org.apache.tomcat.jdbc.pool.ConnectionPool.borrowConnection(ConnectionPool.java:676)     at org.apache.tomcat.jdbc.pool.ConnectionPool.init(ConnectionPool.java:483)     at org.apache.tomcat.jdbc.pool.ConnectionPool.<init>(ConnectionPool.java:154)     at org.apache.tomcat.jdbc.pool.DataSourceProxy.pCreatePool(DataSourceProxy.java:118)     at org.apache.tomcat.jdbc.pool.DataSourceProxy.createPool(DataSourceProxy.java:107)     at org.apache.tomcat.jdbc.pool.DataSourceFactory.createDataSource(DataSourceFactory.java:560)     at org.apache.tomcat.jdbc.pool.DataSourceFactory.getObjectInstance(DataSourceFactory.java:244)     at org.apache.naming.factory.FactoryBase.getObjectInstance(FactoryBase.java:94)     at java.naming/javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:341)
    at org.apache.naming.NamingContext.lookup(NamingContext.java:840)
    at org.apache.naming.NamingContext.lookup(NamingContext.java:159)
    at org.apache.naming.NamingContext.lookup(NamingContext.java:827)
    at org.apache.naming.NamingContext.lookup(NamingContext.java:173)
    at org.apache.catalina.core.NamingContextListener.addResource(NamingContextListener.java:1017)     at org.apache.catalina.core.NamingContextListener.createNamingContext(NamingContextListener.java:557)     at org.apache.catalina.core.NamingContextListener.lifecycleEvent(NamingContextListener.java:253)     at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)     at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5048)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
    at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:713)     at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)     at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)     at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:978)     at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1849)     at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
    at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
    at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)     at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)     at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:773)     at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427)
    at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1576)
    at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)     at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)     at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)     at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)     at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:929)     at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841)
    at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1377)     at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1367)
    at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)     at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)     at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:902)     at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
    at org.apache.catalina.core.StandardService.startInternal(StandardService.java:421)
    at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:932)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:633)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)     at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)     at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.base/java.lang.reflect.Method.invoke(Method.java:567)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:344)
    at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:241) Caused by: java.lang.ClassNotFoundException: Unable to load class: com.mysql.jdbc.Driver from ClassLoader:java.net.URLClassLoader@4617c264;ClassLoader:ParallelWebappClassLoader
Has anyone ever seen this?
Andrea
Re: Installation of EPICS archiver on a single Centos7 machine Jörn Dreyer via Tech-talk
Re: Installation of EPICS archiver on a single Centos7 machine Wang, Lin via Tech-talk
Prev: Re: Forking EPICS processes Grzegorz Kowalski via Tech-talk
Next: Re: Installation of EPICS archiver on a single Centos7 machine Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
