Hello Andrea, Java 16 was released in 2021, but according to MySQL Connector download page as follows, MySQL connector 5.1.21 was released in 2012, which seems to be too old. https://downloads.mysql.com/archives/c-j/ You may want to upgrade the MySQL connector to a newer version (probably 5.1.49 released on 2020) to check if there are compatibility issues between JDK 16 and MySQL connector 5.1.21. Regards, Lin > -----原始邮件----- > 发件人: "Andrea Celentano via Tech-talk" <[email protected]> > 发送时间:2025-02-07 21:50:57 (星期五) > 收件人: [email protected] > 主题: Installation of EPICS archiver on a single Centos7 machine > > Dear colleagues, > > I am currently developing the slow-controls system for a small-scale > experiment (~ 100 PVs), and I'd like to use the EPICS archiver to > properly track them. > > I am using the following setup: > > * Centos7 machine (I cannot change this at the moment) > > * Java JDK version 16.0.2 > > * Archiver release 2.0.5 > (https://urldefense.us/v3/__https://github.com/archiver-appliance/epicsarchiverap/releases/tag/2.0.5__;!!G_uCfscf7eWS!dfP3pgsViV5i5uqOcqz-MWHrFko78Ypy28FydNixfzs_o8UBmRRyBJPjpqZGCwptaFyl7HX0PwxiW6n-WE7VLlepoB0sdgprJNw$ ) > > * Tomcat version apache-tomcat-9.0.20 > > * mysql connector version 5.1.21 > > Following the guide > (https://urldefense.us/v3/__https://epicsarchiver.readthedocs.io/en/latest/sysadmin/installguide.html__;!!G_uCfscf7eWS!dfP3pgsViV5i5uqOcqz-MWHrFko78Ypy28FydNixfzs_o8UBmRRyBJPjpqZGCwptaFyl7HX0PwxiW6n-WE7VLlepoB0seOqUtEE$ ), > I am using the script "single_machine_install.sh". Everything goes well, > I obtain the script "sampleStartup.sh" in the folder where Tomcat > Instances are located. > > If I execute it, and then I open the file "mgmt/logs/catalina.err", I > see the following error. and the archiver does not start. > > ... > > java.sql.SQLException: Unable to load class: com.mysql.jdbc.Driver from > ClassLoader:java.net.URLClassLoader@4617c264;ClassLoader:ParallelWebappClassLoader > context: mgmt > delegate: false > ----------> Parent Classloader: > java.net.URLClassLoader@4617c264 > > at > org.apache.tomcat.jdbc.pool.PooledConnection.connectUsingDriver(PooledConnection.java:292) > at > org.apache.tomcat.jdbc.pool.PooledConnection.connect(PooledConnection.java:212) > at > org.apache.tomcat.jdbc.pool.ConnectionPool.createConnection(ConnectionPool.java:744) > at > org.apache.tomcat.jdbc.pool.ConnectionPool.borrowConnection(ConnectionPool.java:676) > at > org.apache.tomcat.jdbc.pool.ConnectionPool.init(ConnectionPool.java:483) > at > org.apache.tomcat.jdbc.pool.ConnectionPool.<init>(ConnectionPool.java:154) > at > org.apache.tomcat.jdbc.pool.DataSourceProxy.pCreatePool(DataSourceProxy.java:118) > at > org.apache.tomcat.jdbc.pool.DataSourceProxy.createPool(DataSourceProxy.java:107) > at > org.apache.tomcat.jdbc.pool.DataSourceFactory.createDataSource(DataSourceFactory.java:560) > at > org.apache.tomcat.jdbc.pool.DataSourceFactory.getObjectInstance(DataSourceFactory.java:244) > at > org.apache.naming.factory.FactoryBase.getObjectInstance(FactoryBase.java:94) > at > java.naming/javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:341) > at org.apache.naming.NamingContext.lookup(NamingContext.java:840) > at org.apache.naming.NamingContext.lookup(NamingContext.java:159) > at org.apache.naming.NamingContext.lookup(NamingContext.java:827) > at org.apache.naming.NamingContext.lookup(NamingContext.java:173) > at > org.apache.catalina.core.NamingContextListener.addResource(NamingContextListener.java:1017) > at > org.apache.catalina.core.NamingContextListener.createNamingContext(NamingContextListener.java:557) > at > org.apache.catalina.core.NamingContextListener.lifecycleEvent(NamingContextListener.java:253) > at > org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123) > at > org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5048) > at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) > at > org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:713) > at > org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690) > at > org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705) > at > org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:978) > at > org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1849) > at > java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) > at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) > at > org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) > at > java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123) > at > org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:773) > at > org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427) > at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1576) > at > org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309) > at > org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123) > at > org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423) > at > org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366) > at > org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:929) > at > org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841) > at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) > at > org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1377) > at > org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1367) > at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) > at > org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) > at > java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) > at > org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:902) > at > org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262) > at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) > at > org.apache.catalina.core.StandardService.startInternal(StandardService.java:421) > at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) > at > org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:932) > at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) > at org.apache.catalina.startup.Catalina.start(Catalina.java:633) > at > java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native > Method) > at > java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78) > at > java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) > at java.base/java.lang.reflect.Method.invoke(Method.java:567) > at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:344) > at > java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native > Method) > at > java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78) > at > java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) > at java.base/java.lang.reflect.Method.invoke(Method.java:567) > at > org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:241) > Caused by: java.lang.ClassNotFoundException: Unable to load class: > com.mysql.jdbc.Driver from > ClassLoader:java.net.URLClassLoader@4617c264;ClassLoader:ParallelWebappClassLoader > ... > > Has anyone ever seen this? > > Thanks, > > Andrea > > >
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
