1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: PVA Gateway issues with two networks client
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Saisrikiran Mudigonda <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Sat, 8 Feb 2025 19:25:00 -0800
On 2/5/25 22:19, Saisrikiran Mudigonda via Tech-talk wrote:
Hi all,
I forgot to add the mygw.conf file contents in the earlier email. Please find the my gateway configuration details below.
Could you please attach mygw.conf as a text file?
Any help is welcome.
Sai.
On Wed, Feb 5, 2025 at 2:00 PM Saisrikiran Mudigonda <[email protected] <mailto:[email protected]>> wrote:
    Hi all,
    I am facing while running the PVA gateway and configuring two networks. The scenario is that I have class C 192.x.x.x network and 10.0.1.x network configured on the PVA gateway. I am running the IOC (exampleCPP) on 10.0.1.10 (VM) and I am able to access the PV's (PVRint, PVRlong, PVRshort, PVRbyte) from 192.168.0.106 (Windows) machine. Everything works fine.
    Now, I have added a new Windows machine with two NIC cards, Ethernet with 192.168.0.107 and a USB to LAN cable with 10.0.1.33 configured. With this machine, I am able to access only the PV's using 10.0.1.x network (without the PVA gateway running). With the PVA gateway running, I am unable to access the PV's in Phoebus using 192.168.0.107 IP address. I tried to check the ACF rules file, PV list file but to no avail.
    Please find here the ACF rules file and PV list file contents attached here for reference.
    Any help or suggestions why the PV's access using the PVA gateway with the 192.x.x.x network is not working would be appreciated.
    I am suspecting that the PVA gateway is binding the MAC address of the machine with a particular IP address. Can somebody confirm if this is the case?
    Also, is there a way to check the PVA gateway logs as to get a peek at what's happening within the gateway?
    Sai
    Project Software Engineer
    Extreme Photonics Innovation Centre
    TIFR, Hyderabad, India
Re: PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
Prev: Re: Forking EPICS processes Michael Davidsaver via Tech-talk
Next: Archive Viewer John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
Next: Re: PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
