1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: PVA Gateway issues with two networks client
From: Saisrikiran Mudigonda via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Tue, 18 Feb 2025 10:59:14 +0530
Hi Michael,
Very sorry for the late reply. Please find the mygw.conf and acf_rules, pv_names files in text format.
Thanks for your help.
Sai
On Sun, Feb 9, 2025 at 8:55 AM Michael Davidsaver <mdavidsaver at gmail.com> wrote:
On 2/5/25 22:19, Saisrikiran Mudigonda via Tech-talk wrote:
> Hi all,
> I forgot to add the mygw.conf file contents in the earlier email. Please find the my gateway configuration details below.
Could you please attach mygw.conf as a text file?
> Any help is welcome.
> Thanks,
> Sai.
> On Wed, Feb 5, 2025 at 2:00 PM Saisrikiran Mudigonda <smudigonda at tifrh.res.in <mailto:smudigonda at tifrh.res.in>> wrote:
>     Hi all,
>     I am facing while running the PVA gateway and configuring two networks. The scenario is that I have class C 192.x.x.x network and 10.0.1.x network configured on the PVA gateway. I am running the IOC (exampleCPP) on 10.0.1.10 (VM) and I am able to access the PV's (PVRint, PVRlong, PVRshort, PVRbyte) from 192.168.0.106 (Windows) machine. Everything works fine.
>     Now, I have added a new Windows machine with two NIC cards, Ethernet with 192.168.0.107 and a USB to LAN cable with 10.0.1.33 configured. With this machine, I am able to access only the PV's using 10.0.1.x network (without the PVA gateway running). With the PVA gateway running, I am unable to access the PV's in Phoebus using 192.168.0.107 IP address. I tried to check the ACF rules file, PV list file but to no avail.
>     Please find here the ACF rules file and PV list file contents attached here for reference.
>     Any help or suggestions why the PV's access using the PVA gateway with the 192.x.x.x network is not working would be appreciated.
>     I am suspecting that the PVA gateway is binding the MAC address of the machine with a particular IP address. Can somebody confirm if this is the case?
>     Also, is there a way to check the PVA gateway logs as to get a peek at what's happening within the gateway?
>     Thanks,
>     Sai
>     Project Software Engineer
>     Extreme Photonics Innovation Centre
>     TIFR, Hyderabad, India
	"version":2,
	"readOnly":false,
	"clients":[
		"name":"client192",
		"provider":"pva",
		"addrlist":"192.168.0.255",
		"autoaddrlist":false,
		"statusprefix":"GW:STS:"
		"name":"client10",
		"provider":"pva",
		"addrlist":"10.0.1.255",
           "servers":[
                "name":"server10",
		"clients":["client192"],
                "interface":["10.0.1.6"],
		"statusprefix":"GW:STS:",
                "access":"acf_rules1.acf",
                "pvlist":"pv_names2.pvlist"
                "name":"server192",
                "clients":["client10"],
                "interface":["192.168.0.109"],
                "statusprefix":"GW":STS:",
PVRint	ALLOW	DEFAULT
PVRint	ALLOW	OTHER
PVRlong	ALLOW	OTHER
PVRlong	ALLOW	OTHER
PVRlong	DENY	FROM	192.168.0.107
PVRshort	ALLOW	DEFAULT
PVRshort	ALLOW	OTHER
PVRbyte	DENY
UAG(group1) { "pryas" }
UAG(group2) { "EPIC" }
UAG(group3) { "vboxuser" }
UAG(users_10) {"vboxuser", "EPIC", "Admin"}
UAG(users)   { "Malu", "EPIC", "pryas" }
HAG(hostgroup192_1) { "192.168.0.106" }
HAG(hostgroup192_2) { "192.168.0.105" }
HAG(hostgroup192)   { "192.168.0.107", "192.168.0.106", "192.168.0.105" }
HAG(hostgroup10_1)  { "10.0.1.53", "10.0.1.10" }
ASG(DEFAULT) {
    RULE(1,WRITE) {
        UAG(users)
        HAG(hostgroup192)
ASG(OTHER) {
    RULE(1,WRITE) {
        UAG(users_10)
        HAG(hostgroup10_1)
Re: PVA Gateway issues with two networks client Ralph Lange via Tech-talk
PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
Re: PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
Re: PVA Gateway issues with two networks client Michael Davidsaver via Tech-talk
Prev: Re: Calc record with two CP input links ending up in inconsistent state Michael Davidsaver via Tech-talk
Next: Re: PVA Gateway issues with two networks client Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: PVA Gateway issues with two networks client Michael Davidsaver via Tech-talk
ANJ, 18 Feb 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
