On 2/17/25 08:47, Michael Davidsaver wrote:
On 2/17/25 08:20, Aqeel Alshafei - STFC UKRI wrote:
Hello Michael,
I have pulled the new commits.
I have tried putting "servr":"MS", in mbbiDirect. I tried using both NAMSG and AMSG on in different places of the pv link.
it does not set alarm.message from AMSG.
I think this may just be a typo. The key is "sevr". (not "servr" or "serv")
https://urldefense.us/v3/__https://epics-base.github.io/pvxs/pvalink.html*json-reference__;Iw!!G_uCfscf7eWS!ZAXLAuGwxU4jgkheM0vucKGz177HB5Zp791SEFkLkQgJYy2k-RNE-cr5VR6ieY1sG3iT7OVvf-NDaPCruzCNnfp5Dg$
I find myself asking, how should this typo have been detected?
So far, for reasons of forward compatibility, warnings about unknown keys are not
printed by default. Using the "debug" link support will turn them on.
field(INP,{debug:{pva:{pv:"$(P):$(R):CALC", serv: "MS", proc:"CP"}}})
Prints:
pva link parsing unknown string depth=1 key="serv" value="MS"
pvaLink pvaOpenLink fails P:R:SIMULATED: DBLINK* corrupt
At least right now, this does not strike me as a satisfactory answer.
In addition, I have tried to put AMSG and NAMSG on a normal PV without input, output or forward link. alarm message is not being set from AMSG.
As with SEVR and STAT fields, I don't think that AMSG/NAMSG should be set directly.
As I think about it, it would make sense to have a soft device support
which sets SEVR/STAT/AMSG to values read from a link.
we would like to have to set AMSG for normal PVs and PVs with links.
below is the test database file I have used for testing. I have added a Calc PV that just increment from 0 to 5 with High alarm set to major when value = 5. However, the alarm message string is not set
record(calc, "$(P):$(R):COUNTER") {
field(VAL, "0")
field(INPA, "5")
field(CALC, "VAL = A? 0: VAL+1")
field(HIGH, "5")
field(HSV, "MAJOR")
field(AMSG, "COUNTER IN AN ALARM STATE")
field(SCAN, "1 second")
record(calcout, "$(P):$(R):CALC") {
field(INPA, "0x101")
field(CALC, "A")
record (mbbiDirect, "$(P):$(R):SIMULATED") {
field("DESC", "mbbiDirect from calcout")
field(INP,{pva:{pv:"$(P):$(R):CALC", serv: "MS", proc:"CP"}})
record(bi, "$(P):$(R):SIMULATED:B0") {
field(INP, {pva:{pv:"$(P):$(R):SIMULATED.B0", proc:"CP"}})
field(ZNAM, "OFF")
field(ONAM, "ON")
field(OSV, "MAJOR")
field(AMSG, "I AM IN AN ALARM STATE")
Regards
Aqeel
ISIS Controls
*Sent:* 16 February 2025 00:27
*To:* Alshafei, Aqeel (STFC,RAL,ISIS) <[email protected]>
*Cc:* [email protected] <[email protected]>; Finch, Ivan (STFC,RAL,ISIS) <[email protected]>
*Subject:* Re: IOC, QServ, and AMSG / alarm.message
Hello Aqeel,
field(INP,{pva:{pv:"$(P):$(R):CALC", proc:"CP"}})
Try setting the "sevr" key to "MS".
field(INP,{pva:{pv:"$(P):$(R):CALC", sevr:"MS", proc:"CP"}})
I have also updated PR #100, however this is only a change to the test
code, which was not testing everything I thought it was.
On 2/14/25 07:53, Aqeel Alshafei - STFC UKRI wrote:
Hello Michael,
I have switched the test IOC to use pvxs. I've pulled the changes from https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$ <https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$> <https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$ <https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$>>
the alarm.message is not set based on AMSG field. alarm.message string value set to "STATE" then alarm is Minor or Major.
AMSG was set only when the record/PV is in the invalid state. I also tried NMSG field, it behave the same as AMSG, except when PV is invalid is set the alarm.message to "UDF"
so, alarm.message is set when alarm.severity = 3 AND alarm.status = 2. Otherwise, it does not use the AMSG field and set the string value "STATE"
the database below should be able to reproduce what I am encountering. a quick way to make the bi record invalid is to set proc to true instead of "CP" then the alarm.message would be set.
field(CALC, "A")
field(ZNAM, "OFF")
field(ONAM, "ON")
field(OSV, "MAJOR")
field(NAMSG, "I AM IN AN ALARM STATE")
Best Regards
Aqeel AlShafei
ISIS Controls
*From:* Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
*Sent:* 13 February 2025 21:53
*To:* Finch, Ivan (STFC,RAL,ISIS) <[email protected]>
Hi Ivan,
On 2/13/25 08:21, Ivan Finch - STFC UKRI via Tech-talk wrote:
> Hello,
> We have setup a simple IOC with bi records triggered by forward links such as the following:
What you are trying to do should work.
Can you test with: https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$ <https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$> <https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$ <https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$>> ?
> We’ve investigated setting the AMSG and NAMSG fields in the record, but suspect that this is intended to be set programmatically?
The idea is for device support to change to recGblSetSevrMsg()
in places where recGblSetSevr() is used to signal an alarm.
> int recGblSetSevrMsg(void *precord,
> epicsEnum16 new_stat,
> epicsEnum16 new_sevr,
> const char *msg, ...)
So printf() format strings can be used, although there is a
limit of 40 characters (aka. DB_AMSG_SIZE).
> Thank you in advance for any assistance you can provide,
> Ivan Finch
> ISIS Controls
- Re: IOC, QServ, and AMSG / alarm.message Johnson, Andrew N. via Tech-talk
- IOC, QServ, and AMSG / alarm.message Ivan Finch - STFC UKRI via Tech-talk
- Re: IOC, QServ, and AMSG / alarm.message Michael Davidsaver via Tech-talk
- Re: IOC, QServ, and AMSG / alarm.message Aqeel Alshafei - STFC UKRI via Tech-talk
Calc record with two CP input links ending up in inconsistent state Érico Nogueira Rolim via Tech-talk
<2025>
2026
<2025>
2026
