1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: CAENels TetrAMM questions
From: "J. Lewis Muir via Tech-talk" <[email protected]>
Date: Sat, 22 Feb 2025 08:08:14 -0600
On 02/20, Mark Rivers via Tech-talk wrote:
> My units are running firmware 2.9.11.  I see that more recent firmware supports a PKTSIZE command which allows control over the number of readings per Ethernet packet.  That command would be useful to reduce buffering in the TetrAMM when using it for fast feedback.   I tried updating to firmware 3.3.03 today, but the update failed.  Has anyone else tried such an update?
Hi, Mark!
Yes, a few weeks ago, I tried to upgrade the firmware on one of my
TetrAMMs from version 2.0.09 to version 3.3.03, but it only got to 2%
complete and then said the upgrade of the firmware failed and said
something about it having lost connection with the device, I think.
I was running the CAENels Device Manager software on Windows 11 for
ARM64 running in a VM on an ARM64 Mac, though, so Device Manager, which
is x86-64, was running under Windows's built-in x86-64 emulation, and
that all made me wonder whether maybe the Device Manager software just
didn't work right under those conditions.
> I also have a question about the newer firmware and newer TetrAMM manuals.  V1.5 of the TetrAMM User Manual describes the GATE command, which allows collecting data only when a signal level is high.  The EPICS quadEM driver supports that command, and we use it with firmware 2.9.11.  Versions 3.2 and 4.1 of that manual do not describe the GATE command.  Does anyone know if that command has been eliminated in more recent firmware, or is it an oversight in the manual?
No idea.  As you probably noticed, there are still references to the
GATE command in version 4.1 of the TetrAMM User's Manual, which I can
find by searching for GATE, but it's not listed as an actual command.
Lewis
CAENels TetrAMM questions Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] History of EPICS Hartman, Steven via Tech-talk
Next: Re: History of EPICS bob dalesio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: CAENels TetrAMM questions Mark Rivers via Tech-talk
Next: Calcout from other IOC Gabriele Santambrogio via Tech-talk
