1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: CAENels TetrAMM questions
Date: Thu, 20 Feb 2025 22:07:23 +0000
Folks,
We use the CAENels TetrAMM electrometers for X-ray beam position and intensity measurements.
My units are running firmware 2.9.11.  I see that more recent firmware supports a PKTSIZE command which allows control over the number of readings per Ethernet packet.  That command would be useful to reduce buffering in the TetrAMM when using it for fast feedback.   I tried updating to firmware 3.3.03 today, but the update failed.  Has anyone else tried such an update?
I also have a question about the newer firmware and newer TetrAMM manuals.  V1.5 of the TetrAMM User Manual describes the GATE command, which allows collecting data only when a signal level is high.  The EPICS quadEM driver supports that command, and we use it with firmware 2.9.11.  Versions 3.2 and 4.1 of that manual do not describe the GATE command.  Does anyone know if that command has been eliminated in more recent firmware, or is it an oversight in the manual?
Re: CAENels TetrAMM questions J. Lewis Muir via Tech-talk
Prev: RE: Make waveform from ai record Žiga Oven via Tech-talk
Next: Calcout from other IOC Gabriele Santambrogio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: CAENels TetrAMM questions J. Lewis Muir via Tech-talk
