1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Make waveform from ai record
To: EPICS Tech Talk <[email protected]>
Date: Tue, 25 Feb 2025 12:17:04 +0000
Hi Abdallah,
Another way, is to clear/reset the compress record, once the number of samples reaches 200…
You can do this by looking at the NUSE field and once it reaches the value 200, you can extract the waveform and reset the compress record by writing to RES field.
Do keep in mind that this might be an “expensive” option, as you will have additional records, and you will be overwriting the compress record value with 0s on each reset.
Best regards,
Žiga
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, February 24, 2025 11:32
Subject: Re: Make waveform from ai record
On Mon, 24 Feb 2025 at 08:49, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
This maybe a general question not related only to my case, but how to conditionally trigger a PV from within EPICS records? I just had an idea where I want to export or scan the waveform once I had 200 samples exactly, already in the IOC I am tracking the number of samples.
I would use a calcout, FLNKed in a chain fast-ai->ringbuffer->calcout, configured as a counter with an upper limit.
Once the limit is reached, the calcout processes the second array record that takes the snapshot of the ring buffer. (In the calcout, use one of the "Transition..." choices for OOPT and point the OUT to the snapshot record using PP.)
Cheers,
~Ralph
Make waveform from ai record Abdalla Ahmad via Tech-talk
RE: Make waveform from ai record Žiga Oven via Tech-talk
RE: Make waveform from ai record Abdalla Ahmad via Tech-talk
Re: Make waveform from ai record Ralph Lange via Tech-talk
Prev: Re: Make waveform from ai record Ralph Lange via Tech-talk
Next: Re: Using NDPluginGather to collect NDArrays from multiple detectors? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: CAENels TetrAMM questions Mark Rivers via Tech-talk
