1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Using NDPluginGather to collect NDArrays from multiple detectors?
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 25 Feb 2025 14:24:42 +0000
Hi Jörn,
Please set each camera so it is acquiring continuously at 1 Hz.  Then send a screen shot of the Gather plugin, which should have an Array Rate = 3.
Set the HDF5 plugin to Stream mode with NumCapture=100.  Then press the Capture Start button to start streaming.  It should save 3 arrays per second for 33 seconds and then close the file.  Send a screenshot of the HDF5 screen after you press the Capture Start button.
Sent: Tuesday, February 25, 2025 2:25 AM
To: [email protected] <[email protected]>; Mark Rivers <[email protected]>
Hi Mark,
I checked the requirements and all are fullfilled:
1) all detectors are created in the same IOC:
># Adding Basler cameras. Modify the second parameter acording to the camera name.
>aravisConfig("$(PORT1)", "Basler-acA640-100gm-xxxxxxxx")
>aravisConfig("$(PORT2)", "Basler-acA640-100gm-yyyyyyyy")
>aravisConfig("$(PORT3)", "Basler-acA640-120gm-zzzzzzzz")
2) All cameras are of the same type, so the image size is the same (659 * 494) and of the same datatype (UINT8).
The attributes are the standard set. I did not add any.
I attached the screenshots of my NDPluginGather and NDPluginFileHDF5 settings.
There are no errors reported from the HDF5 plugin, but still only one image shows up in the output.
If I do a dump of the file structure, I get:
h5dump -n test_007.h5
HDF5 "test_007.h5" {
FILE_CONTENTS {
 group      /
 group      /entry
 group      /entry/data
 dataset    /entry/data/data
 group      /entry/instrument
 group      /entry/instrument/NDAttributes
 dataset    /entry/instrument/NDAttributes/BayerPattern
 dataset    /entry/instrument/NDAttributes/NDArrayEpicsTSSec
 dataset    /entry/instrument/NDAttributes/NDArrayEpicsTSnSec
 dataset    /entry/instrument/NDAttributes/NDArrayTimeStamp
 dataset    /entry/instrument/NDAttributes/NDArrayUniqueId
 group      /entry/instrument/detector
 group      /entry/instrument/detector/NDAttributes
 dataset    /entry/instrument/detector/NDAttributes/ColorMode
 dataset    /entry/instrument/detector/data -> /entry/data/data
 group      /entry/instrument/performance
 dataset    /entry/instrument/performance/timestamp
I tried the capture and the single mode. Always there is only one image in the file.
I used the commonPluginsExample.cmd with some modifications to be able to use the same file for all three cameras.
The Gather Plugin is from the first camera.
Jörn
Am Mittwoch, 19. Februar 2025, 17:35:20 Mitteleuropäische Normalzeit schrieb Mark Rivers:
> Hi Jörn,
> In principle NDPluginGather can do what you are asking.  There are 2 restrictions:
>   1.
> All of the detectors must be running in the same IOC, i.e. the same process.
>   2.
> All of the detectors must be producing NDArrays with the same dimensions, data type, and attributes.
> The second restriction is due to the way the HDF5 plugin works.  In Stream mode it saves a single dataset of dimensions [Nx, Ny, Nimages].  The datatype of that dataset and also the attribute datasets are determined by the first array it receives.  All subsequent arrays must be the same.  If not, you should see an error at the IOC shell and on the OPI screen.
> If your setup meets these restrictions and you are still having problems, then please send screenshots of the Gather and HDF5 plugin screens.
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
> Sent: Wednesday, February 19, 2025 2:21 AM
> Subject: Using NDPluginGather to collect NDArrays from multiple detectors?
> Hi,
> I would like to write the images from multiple detectors into a single file.
> Therefor I tried to setup an NDPluginGather and connected the Array ports to the asynArray's of the detectors.
> The output of this was connected to an NDPluginFileHDF5. But in the resulting HDF5 file was only one image.
> I gues I misunderstood the functionality of NDPluginGather.
> Looking at the documentation it seems as if it seems that it can only collect data from Plugins (Attributes).
> Is there a way to achieve that, or do I have to live with one file per detector?
> Regards
> Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX
Tel: +49 351 260 3263
Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
http://www.hzdr.de
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
RE: Using NDPluginGather to collect NDArrays from multiple detectors? Mark Rivers via Tech-talk
Using NDPluginGather to collect NDArrays from multiple detectors? Jörn Dreyer via Tech-talk
Re: Using NDPluginGather to collect NDArrays from multiple detectors? Mark Rivers via Tech-talk
Prev: RE: Make waveform from ai record Žiga Oven via Tech-talk
Next: Re: Last call for EPICS on Microsoft VS2010 and VS2012 Compilers Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Using NDPluginGather to collect NDArrays from multiple detectors? Mark Rivers via Tech-talk
Next: RE: Using NDPluginGather to collect NDArrays from multiple detectors? Mark Rivers via Tech-talk
