1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Help interpreting CA protocol
From: Nicholas Devenish via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 26 Feb 2025 21:27:26 +0000
Hi All,
I've been studying the CA protocol documentation (https://docs.epics-controls.org/en/latest/internal/ca_protocol.html), attempting to implement the
CA protocol as a learning exercise to become more familiar with EPICS. I've
found a few points of confusion that I'd appreciate help resolving - I think in
other places the source is referred to as the final word, but I've not yet gotten
good at finding things/navigating through the code base, (so tips on that/documented structure would also be welcomed).
Apologies for several large questions:
CA_READ / CA_READ_NOTIFY Responses
The response is listed (for both responses) as parameter1 being "Server ID": https://docs.epics-controls.org/en/latest/internal/ca_protocol.html#id23, however in the "ECA Error/Status codes section", it explicitly mentions that return codes are sent in CA_PROTO_READ_NOTIFY, and the (invaluable) Wiresharks EPICS plugin at https://github.com/mdavidsaver/cashark does indeed list parameter1 as being the ECA return code.
Is this just a typo in the protocol documentation, and this field should indeed be the Status code instead of the Server ID? If not, presumably I send a CA_PROTO_ERROR instead of the expected response?
CA_PROTO_SEARCH:
In the "comments" section `CA_PROTO_SEARCH` rather definitively says:
    > It is illegal to specify `DO_REPLY` flag whenever the message is sending as UDP datagram, regardless of whether broadcast or multicast is used."
However, immediately below it says:
    > Reply flag will be __generally__ DONT_REPLY when searching using broadcast
The choice of "generally" seems to imply that it can be set on a UDP search? In addition, the description for CA_PROTO_NOT_FOUND response says that it _is_ sent over UDP:
    > Sent in response to CA_PROTO_SEARCH, but only when its DO_REPLY flag was set. Sent over UDP.
Is this supposed to be sent if searching via UDP, and the notify flag is set, or ignored?
Shorter questions:
- CA_VERSION lists several fields as "Must be 0". However, whilst sniffing the broadcast packets on our beamline network, I see quite a lot of searches where these fields have data in (and version is listed as 13). Are these malformed and should be ignored, or pragmatically replied to?
- The ECA Error-status-code-table at https://docs.epics-controls.org/en/latest/internal/ca_protocol.html#eca-error-status-codes lists `ECA_INTERNAL` as Severity "`CA_K_FATAL`". But this doesn't seem to be a valid severity (any more?). Should this read `CA_K_SEVERE`, or there is another (higher) value not documented by the severity code table?
Nick Devenish
(Diamond Light Source)
Re: Help interpreting CA protocol Michael Davidsaver via Tech-talk
Re: Help interpreting CA protocol Torsten Bögershausen via Tech-talk
Re: Help interpreting CA protocol Ralph Lange via Tech-talk
Prev: RE: External: Re: [EXTERNAL] History of EPICS Russ Berg via Tech-talk
Next: Re: Help interpreting CA protocol Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Run-away TCP-tx and TCP-rx Michael Davidsaver via Tech-talk
