1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Request for Help with EPICS Asyn Build Issues
To: Jonathan Hai <[email protected]>, "[email protected]" <[email protected]>
Cc: Aye Chan Moe <[email protected]>
Date: Thu, 6 Mar 2025 18:59:47 +0000
Hi Jonathon,
  • Initially, after compiling Asyn and running the IOC (st.cmd), many Asyn-related commands (asynReport, asynOctetWriteRead, etc.) were missing.
What IOC are you referring to?  One that is included in asyn, or a separate IOC you are building outside of asyn?  If the problem is an IOC outside of asyn, have you verified that the test IOCs inside of asyn build OK?
Please do the following at the top-level of asyn and send the complete output.
make -s clean
make -sj
You said the following:
  • I am encountering persistent build issues while compiling Asyn (asyn-R4-43) with EPICS Base 7.0.9 on Ubuntu 22.04 (Linux x86_64). Despite multiple attempts to resolve the issues, the build process fails with the following error:
Those 2 statements seem contradictory, since first you said you could not build asyn, and then you said that after building asyn you got run-time errors when running the IOC.
I have not tested base 7.0.9, but I have successfully built asyn on 7.0.8 and I think it is unlikely that base 7.0.9 is causing the problem.
From: Tech-talk <[email protected]> On Behalf Of Jonathan Hai via Tech-talk
Sent: Thursday, March 6, 2025 11:52 AM
To: [email protected]
Subject: Request for Help with EPICS Asyn Build Issues
Dear EPICS Tech-Talk,
No rule to make target '../%', needed by 'asynRecord.dbd'.
I would appreciate any guidance on how to fix this issue. Below is a summary of what I have tried so far.
Initial Build Attempt (Missing Asyn Support)
Problem:
  • The error messages included:
·         ERROR: Command asyn_registerRecordDeviceDriver not found.
·         ERROR: Can't open include file "asynRecord.dbd".
·         ERROR: Can't open include file "devEpics.dbd".
Fixes Tried:
  • Verified Asyn libraries (libasyn.so) and DBD files (asynRecord.dbd, devEpics.dbd) exist.
  • Modified testApp/src/Makefile to include:
·         DBD += asyn.dbd
·         DBD += asynRecord.dbd
·         DBD += devEpics.dbd
  • Ensured st.cmd includes:
·         dbLoadDatabase("../../dbd/asyn.dbd")
·         dbLoadDatabase("../../dbd/asynRecord.dbd")
·         dbLoadDatabase("../../dbd/devEpics.dbd")
·         asyn_registerRecordDeviceDriver(pdbbase)
  • Rebuilt Asyn using:
·         make clean
·         make
Result:
  • The missing commands were still not found.
  • asynRecord.dbd and devEpics.dbd were still missing or not properly recognized.
Missing asynRecord.dbd and devEpics.dbd
Problem:
  • Despite confirming that asynRecord.dbd exists (ls -l ~/epics-base/support/asyn/asyn-R4-43/dbd/), the build system could not find it.
  • make install failed with:
·         No rule to make target '../%', needed by 'asynRecord.dbd'.
Fixes Tried:
  • Verified INSTALL_DBD in configure/CONFIG:
·         INSTALL_DBD += asyn.dbd
·         INSTALL_DBD += asynRecord.dbd
·         INSTALL_DBD += devEpics.dbd
  • Checked configure/CONFIG for INSTALL_LOCATION:
·         INSTALL_LOCATION = $(TOP)
  • Ensured asyn.dbd includes:
·         include "asynRecord.dbd"
·         include "devEpics.dbd"
  • Rebuilt Asyn and the IOC:
·         make distclean
·         make clean
·         make -B
Result:
  • The same error persisted:
Debugging Makefile Dependency Issues
Problem:
  • The wildcard rule (%) in the Makefile might be broken or misconfigured.
Fixes Tried:
  • Checked asyn/Makefile for incorrect % rules:
·         ../%: $(INSTALL_LOCATION)/%
    • Commented it out to prevent the broken rule:
o    #../%: $(INSTALL_LOCATION)/%
  • Rebuilt everything:
·         make clean
·         make install
Result:
  • Still getting the same error.
Request for Help
Key Questions
  1. Why is the build system trying to use ../% as a dependency for asynRecord.dbd?
  2. Is there a known issue with Asyn (asyn-R4-43) and EPICS Base compatibility?
  3. How can I properly ensure asynRecord.dbd is installed and recognized?
  4. Are there specific EPICS build settings I should check to resolve this?
System & Build Environment
  • EPICS Base: 7.0.9
  • Asyn Version: asyn-R4-43
  • OS: Ubuntu 22.04 (Linux x86_64)
  • Compiler: gcc (Ubuntu 11.3.0-1ubuntu1~22.04)
I appreciate any insights or suggestions on how to resolve this issue.
Jonathan Hai
Researcher/Tech Monkey
CNBL | Department of Physics and Astronomy
McMaster University
Sapere Aude
Request for Help with EPICS Asyn Build Issues Jonathan Hai via Tech-talk
Prev: Request for Help with EPICS Asyn Build Issues Jonathan Hai via Tech-talk
Next: Re: Request for Help with EPICS Asyn Build Issues Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Request for Help with EPICS Asyn Build Issues Mark Rivers via Tech-talk
