1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Request for Help with EPICS Asyn Build Issues
Cc: Aye Chan Moe <[email protected]>
Date: Thu, 6 Mar 2025 11:01:15 -0800
Hi Jonathan,
If you can share your "application or IOC" in github, I may help you with that issue practically.
Meanwhile, you can check a few example for IOC template at
The most interesting area is the Makefile in the App folder.
Best,
Han
On Thu, Mar 6, 2025 at 9:53 AM Jonathan Hai via Tech-talk <[email protected]> wrote:
Dear EPICS Tech-Talk,
I am encountering persistent build issues while compiling Asyn (asyn-R4-43) with EPICS Base 7.0.9 on Ubuntu 22.04 (Linux x86_64). Despite multiple attempts to resolve the issues, the build process fails with the following error:
No rule to make target '../%', needed by 'asynRecord.dbd'.
I would appreciate any guidance on how to fix this issue. Below is a summary of what I have tried so far.
Initial Build Attempt (Missing Asyn Support)
Problem:
  • Initially, after compiling Asyn and running the IOC (st.cmd), many Asyn-related commands (asynReport, asynOctetWriteRead, etc.) were missing.
  • The error messages included:
    ERROR: Command asyn_registerRecordDeviceDriver not found. ERROR: Can't open include file "asynRecord.dbd". ERROR: Can't open include file "devEpics.dbd".
Fixes Tried:
  • Verified Asyn libraries (libasyn.so) and DBD files (asynRecord.dbd, devEpics.dbd) exist.
  • Modified testApp/src/Makefile to include:
    DBD += asyn.dbd DBD += asynRecord.dbd DBD += devEpics.dbd
  • Ensured st.cmd includes:
    dbLoadDatabase("../../dbd/asyn.dbd") dbLoadDatabase("../../dbd/asynRecord.dbd") dbLoadDatabase("../../dbd/devEpics.dbd") asyn_registerRecordDeviceDriver(pdbbase)
  • Rebuilt Asyn using:
    make clean make
Result:
  • The missing commands were still not found.
  • asynRecord.dbd and devEpics.dbd were still missing or not properly recognized.
Missing asynRecord.dbd and devEpics.dbd
Problem:
  • Despite confirming that asynRecord.dbd exists (ls -l ~/epics-base/support/asyn/asyn-R4-43/dbd/), the build system could not find it.
  • make install failed with:
Fixes Tried:
  • Verified INSTALL_DBD in configure/CONFIG:
    INSTALL_DBD += asyn.dbd INSTALL_DBD += asynRecord.dbd INSTALL_DBD += devEpics.dbd
  • Checked configure/CONFIG for INSTALL_LOCATION:
    INSTALL_LOCATION = $(TOP)
  • Ensured asyn.dbd includes:
    include "asynRecord.dbd" include "devEpics.dbd"
  • Rebuilt Asyn and the IOC:
    make distclean make clean make -B
Result:
  • The same error persisted:
Debugging Makefile Dependency Issues
Problem:
  • The wildcard rule (%) in the Makefile might be broken or misconfigured.
Fixes Tried:
  • Checked asyn/Makefile for incorrect % rules:
    ../%: $(INSTALL_LOCATION)/%
    • Commented it out to prevent the broken rule:
      #../%: $(INSTALL_LOCATION)/%
  • Rebuilt everything:
    make clean make install
Result:
  • Still getting the same error.
Request for Help
Key Questions
  1. Why is the build system trying to use ../% as a dependency for asynRecord.dbd?
  2. Is there a known issue with Asyn (asyn-R4-43) and EPICS Base compatibility?
  3. How can I properly ensure asynRecord.dbd is installed and recognized?
  4. Are there specific EPICS build settings I should check to resolve this?
System & Build Environment
  • EPICS Base: 7.0.9
  • Asyn Version: asyn-R4-43
  • OS: Ubuntu 22.04 (Linux x86_64)
  • Compiler: gcc (Ubuntu 11.3.0-1ubuntu1~22.04)
I appreciate any insights or suggestions on how to resolve this issue.
Jonathan Hai
Researcher/Tech Monkey
CNBL | Department of Physics and Astronomy
McMaster University
Sapere Aude
Jeong Han Lee, Dr.rer.nat.
Lawrence Berkeley National Laboratory
Request for Help with EPICS Asyn Build Issues Jonathan Hai via Tech-talk
Prev: RE: Request for Help with EPICS Asyn Build Issues Mark Rivers via Tech-talk
Next: Re: Request for Help with EPICS Asyn Build Issues Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Request for Help with EPICS Asyn Build Issues Johnson, Andrew N. via Tech-talk
Next: ALS/ALS-U Senior Instrumentation Electronics Engineer Lucas Russo via Tech-talk
