1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Monitoring events over CA doesn't work when using nameserver and old IOCs
From: "Vodopivec, Klemen via Tech-talk" <[email protected]>
Date: Mon, 10 Mar 2025 00:20:16 +0000
At SNS we’ve been finally trying to use a nameserver to reduce the broadcast on the network. During testing, we found that newer CA client will connect to old IOCs (pre 3.14.12) but won’t receive any monitored value. This is true for at least EDM and camonitor with CA client from EPICS 7.0.8.1, while CSS seems to work fine. While camonitor receives an event and displays the timestamp when record processed but no value, the EDM will display a random value in the widget which made testing of the nameserver even more challenging.
After debugging with Wireshark, it appears that the problem lies when a CA Version 13 client connects to a V13 nameserver which redirects it to V11 IOC. In particular, the ChannelAccess V13 introduced dynamic resizing of arrays, which means that the event subscribe command requests 0 elements. The V11 IOC understands such a request as ‘send me events but no data’. This doesn’t happen when V13 client talks directly to V11 IOC, but only when going through the nameserver. I believe that is because the V11 IOC ignores the VERSION request in the subscribe command, and so the V13 clients continues to assume the remote side is V13 which it got from the nameserver. This may sound confusing, so here’s a dump from Wireshark with some of my comments inline, the 7.0.8.1 and 3.14.8.2 are the EPICS base versions that client/nameserver/IOC are compiled against:
# camonitor (base 7.0.8.1) asking NameServer (base 7.0.8.1,PCAS 4.13.3) on port 5062 about the 'TEST' PV
     15 1.296358367    192.168.1.34          192.168.1.34          CA       84     39208->5062 Version(13), Search('TEST',1),
     20 1.328361887    192.168.1.34          192.168.1.34          CA       84     39208->5062 Version(13), Search('TEST',1),
# NameServer (base 7.0.8.1) starts the broadcast search
     25 1.339764217    192.168.1.34          192.168.1.255         CA       84     50905->5064 Version(13), Search('TEST',1),
# IOC (base 3.14.8.2) replies
     26 1.339837224    192.168.1.34          192.168.1.34          CA       84     5064->50905 Version(11), Search Reply(1),
# NameServer (7.0.8.1) establishes the connection and from now on knows the 'TEST' PV
     32 1.340686305    192.168.1.34          192.168.1.34          CA       156    58972->5064 Version(13), User('klemen'), Host('homebox'), Create Request('TEST', cid=1),
     34 1.340729527    192.168.1.34          192.168.1.34          CA       100    5064->58972 Rights(cid=1, RW), Create Reply(cid=1, sid=16),
# camonitor (7.0.8.1) asking NameServer about the 'TEST' PV again
     42 1.392397425    192.168.1.34          192.168.1.34          CA       84     39208->5062 Version(13), Search('TEST',1),
# NameServer (7.0.8.1) replies back pointing it to the IOC
     51 1.412974029    192.168.1.34          192.168.1.34          CA       84     5062->39208 Version(13), Search Reply(1),
# camonitor (7.0.8.1) requests 'TEST' PV from IOC (3.14.8.2)
     56 1.413850566    192.168.1.34          192.168.1.34          CA       156    58980->5064 Version(13), User('klemen'), Host('homebox'), Create Request('TEST', cid=1),
# IOC (3.14.8.2) replies but doesn't include a Version response
     58 1.413913529    192.168.1.34          192.168.1.34          CA       100    5064->58980 Rights(cid=1, RW), Create Reply(cid=1, sid=17),
Linux cooked capture v1
Internet Protocol Version 4, Src: 192.168.1.34, Dst: 192.168.1.34
Transmission Control Protocol, Src Port: 5064, Dst Port: 58980, Seq: 1, Ack: 89, Len: 32
Channel Access
    Command: Rights (0x0016)
    Payload Size: 0
    Client Channel ID: 1
    Rights: RW (0x00000003)
Channel Access
    Command: Create Channel (0x0012)
    Payload Size: 0
    DBR Type: DOUBLE (6)
    Data Count: 1
    Server Channel ID: 17
# camonitor 7.0.8.1 assumes Version(13) from the search request packet #51, and specifies Data Count: 0
     61 1.414229433    192.168.1.34          192.168.1.34          CA       100    58980->5064 Event Add(sid=17, sub=1, mask=5),
Frame 61: 100 bytes on wire (800 bits), 100 bytes captured (800 bits) on interface any, id 0
Transmission Control Protocol, Src Port: 58980, Dst Port: 5064, Seq: 89, Ack: 33, Len: 32
Channel Access
    Command: Event (0x0001)
    Payload Size: 16
    DBR Type: TIME_DOUBLE (20)
    Data Count: 0
    Subscription ID: 1
    Event Mask: 0x0005
No.     Time           Source                Destination           Protocol Length Info
# IOC (3.14.8.2) doesn't recognize Data Count: 0 from Version(13) as dynamic array, and hence sends an event with no elements
     62 1.414314283    192.168.1.34          192.168.1.34          CA       108    5064->58980 Event(sub=1, value=[]),
Frame 62: 108 bytes on wire (864 bits), 108 bytes captured (864 bits) on interface any, id 0
Transmission Control Protocol, Src Port: 5064, Dst Port: 58980, Seq: 33, Ack: 121, Len: 40
Channel Access
    Payload Size: 24
    Data Count: 0
    Subscription ID: 1
    Status: ECA_NORMAL (0x00000001)
    Status: 0
    Severity: 0
    Timestamp: Sat 08 Mar 2025 10:40:26 AM EST
    Padding: 17
For now, we found a workaround: compile the nameserver against base 3.14.8.2. This forces old protocol in the search reply and fixes the issue. Furthermore, the V13 server correctly responds to VERSION command which allows V13 client to properly change the version from V11 it got from nameserver to the V13 that the IOC is sending, so it can use the new features. For obvious reasons, we’d like this to be only a temporary solution. Unfortunately, we still have several old IOCs that we’re slowly upgrading.
On a high level, I thought of a few solutions , and if I was to go down the road of trying to fix it, I’d like to get some input from experts which one would be most optimal:
  • If server doesn’t respond with VERSION command when a channel is connected to a new address, do another search first for old clients – detecting a new address is tricky, as going from UDP to TCP the port numbers will likely change, but only detecting it if the IP changes limits the use of a nameserver on a unique IP
  • Subscribe with data_count=0 only when absolutely sure that the remote side is V13+, ie when server properly replied to VERSION request
  • Use Data Count from Create Channel reply, maybe that’s what CSS does
  • Change the nameserver to return the CA version of the IOC where the PV is found instead of its own. This requires nameserver to drop using PCAS and CA client library from base, and instead implement CA protocol on its own
-- Klemen
Re: Monitoring events over CA doesn't work when using nameserver and old IOCs Ralph Lange via Tech-talk
Prev: Re: SNL question to the community Vodopivec, Klemen via Tech-talk
Next: Re: SNL question to the community Peter Milne via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: SNL question to the community Ralph Lange via Tech-talk
Next: Re: Monitoring events over CA doesn't work when using nameserver and old IOCs Ralph Lange via Tech-talk
