1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: [EXTERNAL] Re: Monitoring events over CA doesn't work when using nameserver and old IOCs
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Vodopivec, Klemen" <vodopiveck at ornl.gov>, Ralph Lange <ralph.lange at gmx.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 10 Mar 2025 15:35:43 +0000
Hi Klemen,
Please take a look at https://github.com/epics-base/epics-base/pull/425 which I believe provided a solution for the 3.15 branch, although we were reluctant to merge it because of the changes to the public APIs. I originally thought the APS was going to need this but in the end we upgraded all our legacy IOCs sufficiently that we don't. Brian's work may be sufficient for you to use as is, but if you want this to be merged we could re-consider that. It's possible we might keep it on the 3.15 branch and not merge it into the 7.0 branch though. Please keep us informed!
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 3/10/25, 7:48AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
Thanks Ralph, it looks like exactly the same problem. Since it’s been reported a while back, do you have a feeling what is the timeline for addressing it, or if anyone is working on it?
-- Klemen
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Date: Monday, March 10, 2025 at 4:54
AM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Re: Monitoring events over CA doesn't work when using nameserver and old IOCs
That's https://github.com/epics-base/epics-base/issues/426, I guess. If so, can you add your mail to the ticket? Thanks! ~Ralph ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍ ‍
Thanks!
~Ralph
Monitoring events over CA doesn't work when using nameserver and old IOCs Vodopivec, Klemen via Tech-talk
Re: Monitoring events over CA doesn't work when using nameserver and old IOCs Ralph Lange via Tech-talk
Re: [EXTERNAL] Re: Monitoring events over CA doesn't work when using nameserver and old IOCs Vodopivec, Klemen via Tech-talk
Prev: Re: SNL question to the community Timo Korhonen via Tech-talk
Next: Re: SNL question to the community Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: [EXTERNAL] Re: Monitoring events over CA doesn't work when using nameserver and old IOCs Vodopivec, Klemen via Tech-talk
Next: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building Jonathan Hai via Tech-talk
ANJ, 10 Mar 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
