Hi Jörn,
At APS we use Sumo to build AreaDetector (including ADCore and ADSupport), many of the standard plugins as external modules, and many IOCs which use these. I suggested changes to the AreaDetector build system
to make that work, although
my PR has bit-rotted somewhat in the 3-4 years since I last worked on it. Our local AreaDetector version has some additional changes that aren’t in the PR, but the plugins don’t require any modification IIRC.
Here is the configure/MODULES file from our camera IOC area, showing that it is possible to do this:
$ cat configure/MODULES
"extra": [
"ADCORE=$(AREA_DETECTOR)/ADCore",
"ADSUPPORT=$(AREA_DETECTOR)/ADSupport"
"module": [
"ADARAVIS:2.2.1-C2-1",
"ADGENICAM:1.10-C2-1",
"ADPOINTGREY:2.9-C2-1",
"ADSPINNAKER:3.3-C2-1",
"AREA_DETECTOR:3.12.1-C2-2",
"ASYN:4.42-C2-2",
"AUTOSAVE:5.10.2-C2-1",
"BASE:7.0.6.1-C2-3",
"BUSY:1.7.3-C2-1",
"CALC:3.7.4-C2-1",
"IOCSTATS:3.2.0-C2-2",
"IOCSTD:4.5.0-C2-1",
"NDDRIVERSTDARRAYS:1.4-C2-1",
"SEQ:2.2.9-C2-1",
"SSCAN:2.11.5-C2-1",
"ZLIB:1.2.11-C2-1"
- Andrew
Complexity comes for free, Simplicity you have to work for.
is it possible to build an areaDetector module outside of the tree?
Background:
I have an areaDetector driver for a special camera that I would like to use in a setup using sumo.
I have sumo setup to to build all the dependencies for areaDetector. I would like to get my camera code included to be alble to use
it in multiple ioc configurations.
My driver compiles if added inside the areaDetector tree, but as a normal EPICS module it fails. Has anybody achieved this?
It look very much that my CONFIG_SITE.local file is not read and thus the relevant configuration is missed.
Jörn
