Hello,
I am currently developing an EPICS IOC for the AXIS-SXRF-60 camera and the Euresys Coaxlink CXP-12 Quad Frame Grabber.
Thanks to ADGenICam and ADEuresys, I’ve been able to save a significant amount of time and effort.
Using the Euresys gentl utility, I extracted the XML files for both the camera and the frame grabber as below:
$ gentl xml
$ ls
6060CXP.xml
Euresys_Coaxlink_TLDataStream_25_02_0.xml
Euresys_Coaxlink_TLDevice_25_02_0.xml
Euresys_Coaxlink_TLInterface_25_02_0.xml
Euresys_Coaxlink_TLSystem_25_02_0.xml
Next, I used the Python scripts in ADGenICam to generate the EPICS database files and OPI screens from the camera’s XML file. These were saved in:
I’d like to know if a similar process can be applied to ADEuresys using the XML files from the Euresys frame grabber.
I created the EPICS database template and OPI screens and placed them in "/ADEuresys/EuresysApp/Db" and "/ADEuresys/EuresysApp/op/edl."
However, when I launched the GUI, most of the PVs displayed zero or N.A as below:
If I can use the database template and GUI in ADEuresys, it would be helpful for troubleshooting and diagnostics.
Does anyone know if ADEuresys has plans to support this in the same way as ADGenICam?
Thank you for your help!
Best regards,
Kuktae
