1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: RE: EPICS build problem
From: Freddie Akeroyd - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: Federico Galdenzi <galdenzi at roma2.infn.it>, Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 16 Apr 2025 11:39:39 +0000
In the startup directory of epics there are two bat files  "win32.bat" and "windows.bat" - which did you use to setup the compiler path etc. ?  win32.bat choses the compiler for 32bit builds and windows.bat for 64bit builds. Your EPICS_HOST_ARCH environment variable is set for a 64bit builds, but the error message suggests your build may be using the 32bit compiler instead as the linker cannot target x64. If you type
    where cl
do you see a path with x64 in it like
    C:\Program Files\Microsoft Visual Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.exe
Or do you see x86 present instead?
Freddie
-----Original Message-----
From: Federico Galdenzi <galdenzi at roma2.infn.it>
Sent: 16 April 2025 08:15
To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>; Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: EPICS build problem
Thanks in advance for the help. I made the log for make and also i can tell that i'm following by letter the tutorial that i've linked to download and build epic base. I've installed perl and make manually.
Best regards.
Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
> Hi,
> We'll need to see a bit more of your build log to see exactly which
> libraries it is having a problem with, can you please post the whole
> build log by doing  something like
>     make clean uninstall
>     make > make.log 2>&1
> And posting make.log
> Thanks,
> Freddie
>> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Federico
>> Galdenzi via Tech-talk
>> Sent: 15 April 2025 12:36
>> To: tech-talk at aps.anl.gov
>> Subject: EPICS build problem
>> Good morning all,
>> I have a problem for installing EPICS on my machine. I've followed
>> the instruction given in this site:
>> https://urldefense.us/v3/__https://docs.epics-
>> controls.org/en/latest/getting-started/installation-windows-
>> plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
>> q5862JV6Ua7PGUqoY-cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
>> but it seems that i'm missing something, because i get the "make"
>> fatal error
>> LNK1112: module machine type 'x86' conflicts with target machine type
>> 'x64'.
>> I'm kinda new to this world but i cant' manage to understand what i'm
>> doing wrong. It seems that i'm using 32 bit libraries on a 64 bit
>> environment, but i'm using Visual Studio latests kit's for developing
>> in C++ in both 64 and
>> 32 bit.
>> What can i do?
Re: EPICS build problem Federico Galdenzi via Tech-talk
RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: EPICS build problem Federico Galdenzi via Tech-talk
Next: RE: Problem with Sequencer Dudley, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Next: Re: EPICS build problem Federico Galdenzi via Tech-talk
ANJ, 16 Apr 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
