Hi Freddie,
I've followed this part of the tutorial:
Download the distribution from e.g.
https://urldefense.us/v3/__https://epics-controls.org/download/base/base-7.0.4.1.tar.gz__;!!G_uCfscf7eWS!f_jetzd-K2r1G-0E_Zv9zjtYiGo8BXPMtqLcSDchZBqTZpbQiAip-iIgDvINnl8VtGXPn7xXVeNDYSAvmHfXSULPBoc$ .
Unpack it into a work directory.
Open a Windows command prompt and change into the directory you unpacked
EPICS Base into.
Note: The complete path of the current directory mustn’t contain any
spaces or parentheses. If your working directory path does, you can do
another cd into the same directory, replacing every path component
containing spaces or parentheses with its Windows short path (that can
be displayed with dir /x).
Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for 64bit
builds, win32-x86 for 32bit builds).
Run the vcvarsall.bat script of your installation (the exact path
depends on the type and language of installation) to set the environment
for your build.
Run make (or gmake if using the version from Strawberry Perl).
When i cd to my folder, and typed "where cl" it doesnt' return anything
not even after i ran the vcvarsall.bat. I didnt' ran the windows.bat
because it wasn't written.
Should i do it directly from the folder?
Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
In the startup directory of epics there are two bat files "win32.bat"
and "windows.bat" - which did you use to setup the compiler path etc. ?
win32.bat choses the compiler for 32bit builds and windows.bat for
64bit builds. Your EPICS_HOST_ARCH environment variable is set for a
64bit builds, but the error message suggests your build may be using
the 32bit compiler instead as the linker cannot target x64. If you type
where cl
do you see a path with x64 in it like
C:\Program Files\Microsoft Visual
Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.exe
Or do you see x86 present instead?
Freddie
-----Original Message-----
From: Federico Galdenzi <galdenzi at roma2.infn.it>
Sent: 16 April 2025 08:15
To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>;
Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: EPICS build problem
Thanks in advance for the help. I made the log for make and also i can
tell that i'm following by letter the tutorial that i've linked to
download and build epic base. I've installed perl and make manually.
Best regards.
Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
We'll need to see a bit more of your build log to see exactly which
libraries it is having a problem with, can you please post the whole
build log by doing something like
make clean uninstall
make > make.log 2>&1
And posting make.log
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Federico
Galdenzi via Tech-talk
Sent: 15 April 2025 12:36
To: tech-talk at aps.anl.gov
Subject: EPICS build problem
Good morning all,
I have a problem for installing EPICS on my machine. I've followed
the instruction given in this site:
https://urldefense.us/v3/__https://docs.epics-
controls.org/en/latest/getting-started/installation-windows-
plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
q5862JV6Ua7PGUqoY-cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
but it seems that i'm missing something, because i get the "make"
fatal error
LNK1112: module machine type 'x86' conflicts with target machine type
'x64'.
I'm kinda new to this world but i cant' manage to understand what i'm
doing wrong. It seems that i'm using 32 bit libraries on a 64 bit
environment, but i'm using Visual Studio latests kit's for developing
in C++ in both 64 and
32 bit.
What can i do?
- RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
- EPICS build problem Federico Galdenzi via Tech-talk
- Re: EPICS build problem Federico Galdenzi via Tech-talk
RE: Problem with Sequencer Dudley, David via Tech-talk
<2025>
<2025>
