Folks,
I have a couple of questions about the Eiger2 that I'm hoping someone can help me with:
#1
I am working on the EPICS driver for the Eiger2 with the Stream2 interface. I have it working fine with Compression=None and Compression=bslz4. However, I
am having trouble with compression=lz4. It appears to me that the lz4 compression with Stream2 is different from the lz4 compression with Stream.
These are the compressed sizes I see for a radioactive source and 10 second count time.
Interface
Compression
Compressed data size
Stream
bslz4
248 KB
Stream2
bslz4
248 KB
Stream
lz4
771 KB
Stream2
lz4
1,119 KB
The data size for bslz4 is the same for Stream and Stream2, and I can decompress using the same code.
However, the data size with lz4 is significantly larger with Stream2 than with Stream. More importantly when I try to decompress the lz4 data from Stream2
using the same code I use for Stream it crashes.
Has the lz4 compression in Stream2 changed from Stream, and is this documented somewhere?
#2
When I enable threshold2 I expect that the HDF5 file written by the Dectris server should contain 2 images, one for threshold1 and one for threshold2. However,
the file size with threshold2 enabled is the same as when it is disabled. In both cases h5dump –header shows the following for the data:
DATASET "data" {
DATATYPE H5T_STD_U32LE
DATASPACE SIMPLE { ( 1, 1062, 1028 ) / ( H5S_UNLIMITED, 1062, 1028 ) }
ATTRIBUTE "image_nr_high" {
DATATYPE H5T_STD_U64LE
DATASPACE SCALAR
ATTRIBUTE "image_nr_low" {
DATASPACE SCALAR
What am I misunderstanding?
