1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Unexpected duplicate activation with ODLY > 0
To: [email protected]
Date: Thu, 24 Apr 2025 16:43:33 +0200
Dear madam/sir,
I run into behavior (of EPICS) I am not able to explain. On EPICS 7.0.6.1 (Windows 64-bit build, MSVS, Windows 11), I load the following DB:
record(longin, "$(P):counter") {
    field(PINI, "1")
    field(INP, "$(P):inc PP")
    field(SCAN, ".1 second")
record(calc, "$(P):inc") {
    field(INPA, "$(P):counter")
    field(CALC, "A+1")
record(fanout, "$(P):trigger") {
    field(SELM, "All")
    field(LNK1, "$(P):delay")
record(calcout, "$(P):delay") {
    field(ODLY, "1")
    field(OOPT, "Every Time")
    field(OUT, "$(P):target PP")
record(longin, "$(P):target") {
    field(INP, "$(P):counter")
And, I run "camonitor test:target" to observe the output in a console. Then:
* When I use IOCSH and run "dbtr test:trigger" or "dbpf test:trigger 0", I notice that "test:target" is updated per call after the delay of 1 second (the ODLY of "$(P):delay"). This is expected.
* When I run "dbtr test:trigger" multiple times within 1 second, I get one update of "test:target". This is expected.
* When I run "dbpf test:trigger 0" multiple times within 1 second, "test:target" is updated twice with 1 second between updates. The same happens when I run "caput test:trigger 0" multiple times within 1 second.
Based on documentation (https://epics.anl.gov/base/R7-0/6-docs/fanoutRecord.html) fanout should ignore the field VAL and it's purpose is to trigger. Therefore, I am lost right now. Is there a chance someone else may try the DB whether this can be reproduced outside my system, please? I might be just my machine.
Thank you.
Sincerely,
Ivo Hanak
Re: Unexpected duplicate activation with ODLY > 0 Ralph Lange via Tech-talk
Prev: Re: EPICS VAL/DVAL garbage value Mark Rivers via Tech-talk
Next: Re: Unexpected duplicate activation with ODLY > 0 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
