1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Frequent Retrieval Service Failures on Archiver Appliance Node
From: "Shankar, Murali via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 28 Apr 2025 12:49:16 +0000
When you say "stops", what does that mean? Does the process die? In which case, is there a core file? Or does the HTTP endpoint become unresponsive? In which case, have you tried sending a kill -SIGQUIT to see what's going on? There's usually some info in the stdout/stderr ( catalina.out or catalina.err ) in case of system issues. Do you see anything there?
Murali
Prev: Re: Problems setting up MCA BrukerQM100 Mark Rivers via Tech-talk
Next: Re: Problems setting up MCA BrukerQM100 Lott, Eva via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Frequent Retrieval Service Failures on Archiver Appliance Node 吕慧慧 via Tech-talk
Next: Problems setting up MCA BrukerQM100 Lott, Eva via Tech-talk
ANJ, 28 Apr 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
