Hi Eva,
That is not correct. The BrukerQM100Config command is defined here:
It is
int BrukerQM100Config(const char *portName, char *user, char *passwd, char *server, int spuno)
The portName argument to that command is the name of the asyn port to create for this driver. It is not the name of a drvAsynIPPort.
You don't need to build your IOC with drvAsynIPPort. The IP communication is done using their DLL, not with asyn.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Lott, Eva via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, April 28, 2025 4:14 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Problems setting up MCA BrukerQM100
I've been trying to set up an MCA ioc for the Bruker XFlash. I've built `mcaBrukerQM100.exe` (linking the hardware control dll), and am now in the process of writing the iocBoot for it.
My problem is that this ioc doesn't link `drvIPPortConfigure` - I need an IP port for running `BrukerQM100Config`. I've tried linking drvAsynIPPort.dbd in
https://github.com/epics-modules/mca/blob/master/mcaApp/RontecSrc/mcaBrukerQM100Include.dbd to no avail.
Does anyone have any examples of a production mcaBrukerQM100 support module that I can look at?
Eva
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den*die Absender*in und vernichten Sie diese Mail. Das unerlaubte Kopieren, die Veröffentlichung
sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This email may contain confidential and/or proprietary information. If you have received this e-mail in error, please inform the sender immediately and destroy this e-mail. Unauthorized copying, publishing or distribution of this e-mail is not permitted.
