1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: FYI, the msys2 compilation approach is not working
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 28 Apr 2025 16:38:29 +0000
Hi all,
I’m following the instructions on this webpage for installing EPICS using msys2.
Everything worked fine up until the “Download and build EPICS Base” section. After running “export EPICS_HOST_ARCH=windows-x64-mingw”, I get the following errors. Do you suggest that I potentially change the architecture to windows-x64, rather than windows-x64-mingw?
../osi/os/WIN32/epicsTempFile.c: In function ‘epicsTempFile’:
../osi/os/WIN32/epicsTempFile.c:31:20: warning: implicit declaration of function ‘_tempnam’; did you mean ‘tempnam’? [-Wimplicit-function-declaration]
   31 |     char * pName = _tempnam("c:\\tmp", "epics");
      |                    tempnam
../osi/os/WIN32/epicsTempFile.c:31:20: warning: initialization of ‘char *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
../osi/os/WIN32/epicsTempFile.c:45:24: error: ‘_O_CREAT’ undeclared (first use in this function); did you mean ‘O_CREAT’?
   45 |         int openFlag = _O_CREAT | _O_EXCL | _O_RDWR |
      |                        O_CREAT
../osi/os/WIN32/epicsTempFile.c:45:24: note: each undeclared identifier is reported only once for each function it appears in
../osi/os/WIN32/epicsTempFile.c:45:35: error: ‘_O_EXCL’ undeclared (first use in this function); did you mean ‘O_EXCL’?
      |                                   O_EXCL
../osi/os/WIN32/epicsTempFile.c:45:45: error: ‘_O_RDWR’ undeclared (first use in this function); did you mean ‘O_RDWR’?
      |                                             O_RDWR
../osi/os/WIN32/epicsTempFile.c:46:13: error: ‘_O_SHORT_LIVED’ undeclared (first use in this function)
   46 |             _O_SHORT_LIVED | _O_BINARY | _O_TEMPORARY;
../osi/os/WIN32/epicsTempFile.c:46:30: error: ‘_O_BINARY’ undeclared (first use in this function); did you mean ‘O_BINARY’?
      |                              O_BINARY
../osi/os/WIN32/epicsTempFile.c:46:42: error: ‘_O_TEMPORARY’ undeclared (first use in this function)
../osi/os/WIN32/epicsTempFile.c:47:40: error: ‘_S_IWRITE’ undeclared (first use in this function); did you mean ‘S_IWRITE’?
   47 |         int fd = open(pName, openFlag, _S_IWRITE);
      |                                        S_IWRITE
../osi/os/WIN32/epicsTempFile.c:50:24: warning: implicit declaration of function ‘_fdopen’; did you mean ‘fdopen’? [-Wimplicit-function-declaration]
   50 |             pNewFile = _fdopen(fd, "w+b");
      |                        fdopen
../osi/os/WIN32/epicsTempFile.c:50:22: warning: assignment to ‘FILE *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO      -O3   -Wall      -m64    -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/WIN32 -I../../../../include         -o ccl.obj -c ../flex/ccl.c
In file included from ../flex/flexdef.h:38,
                 from ../flex/ccl.c:29:
../osi/os/WIN32/osiUnistd.h:16:10: fatal error: direct.h: No such file or directory
   16 | #include <direct.h>
compilation terminated.
make[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
make[4]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom/src/O.windows-x64-mingw'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[3]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
make[1]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules'
make: *** [configure/RULES_DIRS:85: modules.install] Error 2
Purple ribbon awareness
RE: FYI, the msys2 compilation approach is not working Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: RE: Handling Polling and CPU Bottleneck for Large Image Capture in areaDetector Mark Rivers via Tech-talk
Next: RE: FYI, the msys2 compilation approach is not working Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Handling Polling and CPU Bottleneck for Large Image Capture in areaDetector Kim, Kuktae via Tech-talk
