1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Unable to mind .lib files after successfully compiling EPICS using mingw64
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: Freddie Akeroyd - STFC UKRI <[email protected]>, Mark Rivers <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 29 Apr 2025 15:56:15 +0000
Hi all,
I decided to recompile EPICS by using Strawberry Perl and Visual Studio. MATLAB CA works beautifully now.
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: Tuesday, April 29, 2025 4:04:40 AM
To: Wang, Andrew <[email protected]>; Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>
Subject: RE: Unable to mind .lib files after successfully compiling EPICS using mingw64
The default DLL search order includes the directory of the main executable and PATH, so ca.dll / com.dll in the same directory as  mca.mexw64 may not be enough unless that directory also gets added by matlab automatically. Try moving Com.dll and ca.dll to either a directory in your PATH or the same directory as  matlab.exe
Freddie
From: Tech-talk <[email protected]> On Behalf Of Wang, Andrew via Tech-talk
Sent: 29 April 2025 03:08
To: Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>
Hi Mark,
Thanks for the clarification. Not sure if you can help me with this, but I was able to get mca compiled using mex on MATLAB with this command (I removed parts of the path for just this email for reasons):
mex -R2017b mca.cpp MCAError.cpp Channel.cpp ...
            <TOP>\epics-base\lib\windows-x64-mingw\libCom.dll.a ...
            <TOP>\epics-base\lib\windows-x64-mingw\libca.dll.a ...
           -D_MINGW ...
           -IC:\Users\wang126\epics-base\include ...
           -IC:\Users\wang126\epics-base\include\os\WIN32 ...
           -IC:\Users\wang126\epics-base\include\compiler\gcc ...
           -v
On MATLAB 2024b, mex completed successfully. However when I went to run mca.mexw64, it states that:
Invalid MEX-file <TOP>\matlab_ca\mca.mexw64': The specified module could not be found.
Reading through the MATLAB forums, I used the dependency tool that came with MSVC to find what its dependencies are. They are listed below.
Dump of file mca.mexw64
File Type: DLL
  Image has the following dependencies:
    libmex.dll
    libmx.dll
    KERNEL32.dll
    msvcrt.dll
    ca.dll
    Com.dll
I have ca.dll and Com.dll in the same directory as mca.mexw64. The others are found in PATH. I feel like I am missing something important, but not sure what it is.
Sent: Monday, April 28, 2025 6:18 PM
To: EPICS tech-talk <[email protected]>; Wang, Andrew <[email protected]>
When you build dynamically on Windows with VS there are 2 files:
  • .lib contains the symbols
  • .dll contains the code
When you link, as in the Matlab Makefile, you only link with the .lib files.  It finds the .dll files at run-time.
When you build statically on Windows with VS there is only a .lib file, which contains both the symbols and the code.  It does not need to find .dll files at run-time.
I am sure pretty sure that Matlab is linking to the dynamic DLLs for ca and Com.
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Monday, April 28, 2025 8:01 PM
Subject: Unable to mind .lib files after successfully compiling EPICS using mingw64
Hi all,
I have been tasked with building EPICS on Windows. I was able to get it compiling using mingw64. I basically followed the instructions here (https://docs.epics-controls.org/en/latest/getting-started/installation-windows-msys2.html), albeit I did not use the tar.gz file. I instead cloned the epics-base repository.
I have been able to run an IOC and all of that. However, now I am trying to get mca to work, which requires com.lib and ca.lib. However, I do not see these in my lib directory. I only find com.dll.a and ca.dll.a, which to my understanding is not a static library.
The examples compilations in mca all use .lib. (https://github.com/epics-extensions/matlab_ca/blob/master/alt_compile/mcacompile_win64_mscc.m)
Please advise?
Purple ribbon awareness
Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Ralph Lange via Tech-talk
Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Mark Rivers via Tech-talk
RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
Next: RE: Would this motor record documentation be considered "current" Foster, Andrew (-,RAL,TEC) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Ralph Lange via Tech-talk
