1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Phoebus alarm tree shows stale configuration
From: Majer Karel via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 30 Apr 2025 13:11:33 +0000
Hello,
We have recently put Phoebus alarm server into operation and while the server seems to run OK, I have troubles with alarm tree view in Phoebus client.
When I open alarm tree I often get incomplete configuration. It seems that the client has not reached the end of Kafka log. I usually get correct configuration after several tries.
I run alarm server and Kafka in containers using Docker compose. I’m using apache/kafka:4.0.0 image for Kafka and ghcr.io/controlsystemstudio/phoebus/service-alarm-server:master for alarm server service.
I’m using Phoebus 4.7.3 release version as a client on Rocky Linux 9.
Do you have any experience with similar behavior?
Karel Majer
Karel Majer | Senior Software Developer
Tel: +420 266 051 514
Email:
karel.majer at eli-beams.eu
ELI Beamlines Facility|The Extreme Light Infrastructure ERIC
Za Radnicí 835, 252 41 Dolní Břežany, Czech Republic
www.eli-laser.eu|www.eli-beams.eu
Prev: Re: Would this motor record documentation be considered "current" Torsten Bögershausen via Tech-talk
Next: Re: Would this motor record documentation be considered "current" Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: Would this motor record documentation be considered "current" Peterson, Kevin M. via Tech-talk
Next: Control System Studio Original Version Startup Error Vargo, Will via Tech-talk
ANJ, 06 May 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
