1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Would this motor record documentation be considered "current"
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Paduan Donadio, Marcio" <marcio at slac.stanford.edu>
Date: Tue, 6 May 2025 21:50:21 +0000
I gave a talk on "Writing Motor Drivers" back in a 2015 EPICS training at the APS:
https://epics.anl.gov/docs/APS2015.php
Slides:
https://epics.anl.gov/docs/APS2015/17-Motor-Driver.pdf
Video:
https://epics.anl.gov/docs/APS2015/17-Motor-Driver.m4v
I wouldn't call it good, but much of the info is still relevant.  I created the virtual motor controller, which now resides in the motorVMC module, specifically for the 2015 training sessions.
Kevin
Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
RE: Would this motor record documentation be considered "current" Foster, Andrew (-,RAL,TEC) via Tech-talk
Re: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
Re: Would this motor record documentation be considered "current" Torsten Bögershausen via Tech-talk
Re: Would this motor record documentation be considered "current" Paduan Donadio, Marcio via Tech-talk
Prev: Re: EPICS app, Db Makefile, rule for python-generated Db file Johnson, Andrew N. via Tech-talk
Next: Checksum for StreamDevice input with regular expression Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: RE: Would this motor record documentation be considered "current" Mark Rivers via Tech-talk
Next: Phoebus alarm tree shows stale configuration Majer Karel via Tech-talk
ANJ, 08 May 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
