1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Build Problem for IOC
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Federico Galdenzi <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 9 May 2025 11:55:36 +0000
Have you run the startup/windows.bat or vcvarsall.bat from the cmd window prior to typing make for the ioc? I think your computer may have the compiler (cl) in the system PATH, but it will not work fully as it is missing some environment variables unless one of these bat files is run.
Freddie
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Federico Galdenzi via Tech-talk
Sent: 09 May 2025 12:33
To: [email protected]
Subject: Build Problem for IOC
Hi all again,
I'm sorry to bother you all with my trivial questions but i think i messed something that i cant' fix. When i try to build the test IOC following the instructions here:
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/getting-started/installation-windows-plain.html__;!!G_uCfscf7eWS!Ypx43Eshsktai-zDAgSTdWH1mjDfddYk0xc8YuAcu1MbCDRf_-0Nb1BXyJIeZaqm66Auia6SKBm7Q1vcqX34py0EYuQ$ .
However, when i try to build the IOC, i get an error. I think i messed up the tools installations but i'm not sure. I'm sorry to bother, but this is also my first approach to coding in C/C++.
Regards.
Re: Build Problem for IOC Federico Galdenzi via Tech-talk
Prev: Build Problem for IOC Federico Galdenzi via Tech-talk
Next: Re: Build Problem for IOC Federico Galdenzi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
