1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Build Problem for IOC
From: Federico Galdenzi via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 09 May 2025 13:32:31 +0200
Hi all again,
I'm sorry to bother you all with my trivial questions but i think i messed something that i cant' fix. When i try to build the test IOC following the instructions here: https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/getting-started/installation-windows-plain.html__;!!G_uCfscf7eWS!Ypx43Eshsktai-zDAgSTdWH1mjDfddYk0xc8YuAcu1MbCDRf_-0Nb1BXyJIeZaqm66Auia6SKBm7Q1vcqX34py0EYuQ$ . However, when i try to build the IOC, i get an error. I think i messed up the tools installations but i'm not sure. I'm sorry to bother, but this is also my first approach to coding in C/C++.
Regards.
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./configure install
make[1]: Entering directory 'C:/Epics/testioc/configure'
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/Epics/testioc/configure/O.windows-x64'
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory 'C:/Epics/testioc/configure/O.windows-x64'
make[1]: Leaving directory 'C:/Epics/testioc/configure'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./testApp install
make[1]: Entering directory 'C:/Epics/testioc/testApp'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./src install
make[2]: Entering directory 'C:/Epics/testioc/testApp/src'
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/Epics/testioc/testApp/src/O.windows-x64'
"Creating dbd file test.dbd"
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -IC:/Epics/base-7.0.9/dbd -o test.dbd base.dbd
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -IC:/Epics/base-7.0.9/dbd    -o test_registerRecordDeviceDriver.cpp \
            ../O.Common/test.dbd test_registerRecordDeviceDriver C:/Epics/testioc
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m test_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/Epics/base-7.0.9/include/compiler/msvc -IC:/Epics/base-7.0.9/include/os/WIN32 -IC:/Epics/base-7.0.9/include        test_registerRecordDeviceDriver.obj test_registerRecordDeviceDriver.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m testMain.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/Epics/base-7.0.9/include/compiler/msvc -IC:/Epics/base-7.0.9/include/os/WIN32 -IC:/Epics/base-7.0.9/include        testMain.obj ../testMain.cpp
"Installing created dbd file ../../../dbd/test.dbd"
mkdir ../../../dbd
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/Epics/base-7.0.9/include/compiler/msvc -IC:/Epics/base-7.0.9/include/os/WIN32 -IC:/Epics/base-7.0.9/include        -c test_registerRecordDeviceDriver.cpp
C:\Epics\testioc\testApp\src\O.windows-x64\test_registerRecordDeviceDriver.cpp(4): fatal error C1083: Cannot open include file: 'string.h': No such file or directory
make[3]: *** [C:/Epics/base-7.0.9/configure/RULES_BUILD:268: test_registerRecordDeviceDriver.obj] Error 2
make[3]: Leaving directory 'C:/Epics/testioc/testApp/src/O.windows-x64'
make[2]: *** [C:/Epics/base-7.0.9/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/Epics/testioc/testApp/src'
make[1]: *** [C:/Epics/base-7.0.9/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory 'C:/Epics/testioc/testApp'
make: *** [C:/Epics/base-7.0.9/configure/RULES_DIRS:85: testApp.install] Error 2
RE: Build Problem for IOC Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: RE: How to know which CA client(IP address) modified a PV Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Next: RE: Build Problem for IOC Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: How to know which CA client(IP address) modified a PV Shen, Guobao via Tech-talk
