1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: How to know which CA client(IP address) modified a PV
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 13 May 2025 11:35:27 +0000
The deployment here at APS is exactly what Andrew presented in 2018 as Ralph citated in the [2].
We are using logstash to receive the message, which includes the change info.
One thing to be caution is to configure the IOC not sending every PV changes, for example those PV used in the fast orbit feedback system.
Guobao
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Date: Tuesday, May 13, 2025 at 2:36
 AM
To: EPICS Tech Talk <[email protected]>
caPutLog is used in a lot of installations, usually with a remote server receiving the messages.
(The behaviour that Guobao described is unknown to me.)
Traditionally, iocLogServer would be used for that, most often on a different port to keep the caPut logs separate from the regular IOC logs.
Note that iocLogServer is deprecated, and we intend to drop it at some point in the future. No worries: this will not happen anytime soon.
Compatible log stash configurations can be used as a replacement without changing the IOC side. For more information, look at this issue ticket for the initial discussion [1] and Andrew's slides at the EPICS Collaboration Meeting in 2018 [2].
Cheers,
~Ralph
[2] https://events01.synchrotron.org.au/event/85/contributions/2601/
How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
Re: How to know which CA client(IP address) modified a PV J. Lewis Muir via Tech-talk
Re: How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
RE: How to know which CA client(IP address) modified a PV Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Re: How to know which CA client(IP address) modified a PV Shen, Guobao via Tech-talk
Re: How to know which CA client(IP address) modified a PV Ralph Lange via Tech-talk
Prev: Custom filters Lucas Magalhães via Tech-talk
Next: RE: EPICS Support for NI-9223 Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: How to know which CA client(IP address) modified a PV Ralph Lange via Tech-talk
Next: Build Problem for IOC Federico Galdenzi via Tech-talk
