1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: fedora 42 and makeBaseApp -t example
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 12 May 2025 14:22:02 +0200
The issue is related to f42 changing the default C standard to C23.
There were a few commits in April fixing Base for that, but it seems the example code did not get the necessary updates.
I'm sure that a Pull Request would be highly appreciated... ;-)
Quick workaround:
Include -std=c99 in USR_CFLAGS in the Base configuration.
Cheers,
~Ralph
fedora 42 and makeBaseApp -t example Heinz Junkes via Tech-talk
Re: fedora 42 and makeBaseApp -t example Ralph Lange via Tech-talk
Re: fedora 42 and makeBaseApp -t example Heinz Junkes via Tech-talk
Prev: Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Ralph Lange via Tech-talk
Next: Re: How to know which CA client(IP address) modified a PV Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: fedora 42 and makeBaseApp -t example Heinz Junkes via Tech-talk
Next: Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
