1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Area Detector manta camera communication issue
From: Matt Shaw - STFC UKRI via Tech-talk <[email protected]>
Date: Wed, 14 May 2025 10:55:42 +0000
I’m having an issue with connecting to certain manta cameras (G-235B & G-319B)
The cameras are pingable from my ioc, and I can see them via arv-tool-0.8, but when I try to connect via the IOC I get the following
aravisConfig("CAM08", "xxx.xxx.xxx.xxx", 0, 0, 0)
ADAravis: Looking for camera xxx.xxx.xxx.xxx...
(process:3830): XML-CRITICAL **: 11:09:34.977: Input is not proper UTF-8, indicate encoding !
Bytes: 0xEF 0x61 0x64 0x3C
ADAravis: Your tick frequency is 1000000000
So your timestamp resolution is 1.000000 ns
2025/05/14 11:09:34.984 ADAravis:makeStreamObject: Making stream failed, err=No stream channel found, retrying in 5s...
(process:3830): XML-CRITICAL **: 11:09:40.352: Input is not proper UTF-8, indicate encoding !
(process:3830): GLib-WARNING **: 11:09:40.356: GError set over the top of a previous GError or uninitialized memory.
This indicates a bug in someone's code. You must ensure an error is NULL before it's set.
The overwriting error message was: No stream channel found
2025/05/14 11:09:40.357 ADAravis:makeStreamObject: Making stream failed, err=No stream channel found
If I try to pull info from the camera via arv-tool-0.8 I get a similar response:
~]$ arv-tool-0.8 -a 192.168.1.147
(arv-tool-0.8:5000): XML-CRITICAL **: 11:37:59.483: Input is not proper UTF-8, indicate encoding !
I assume that this is an issue with the XML coming from the camera in the wrong format / missing some data, but I can’t find reference to this “XML-CRITICAL”
Has anyone experienced this behaviour before and been able to fix?
Thank you in advance
Matt Shaw
(Daresbury Lab)
Re: Area Detector manta camera communication issue Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: RE: Help with BiSS encoders and Galil controller Mark via Tech-talk
Next: Re: Area Detector manta camera communication issue Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
