Dear EPICS community, I have a lot of records
that I only need to process once, e.g. to retrieve an
identification string or configuration info that I don't need to
SCAN periodically. But there are cases,
when this procedure fails, e.g. in case the IOC is already
running and the device is not "ready" before iocInit. Then these
records are invalid and I need to process them manually. Can you give me a best
practice advice on how to deal with this situation? In most cases I use asyn + streamdevice to talk to my devices so I guess might be some kind of signal comming from asyn "hey, the device is back online, now you can (re)process your PINI-records"? Thank you very much in
advance. Best regards
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
