1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Process PINI-Record again as soon as device is reconnected
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Cc: "Dr. Simon Friederich" <[email protected]>
Date: Fri, 16 May 2025 19:34:09 +0200
On Fri, 16 May 2025 at 16:05, Dr. Simon Friederich via Tech-talk <[email protected]> wrote:
In most cases I use asyn + streamdevice to talk to my devices so I guess might be some kind of signal comming from asyn "hey, the device is back online, now you can (re)process your PINI-records"?
That's what StreamDevice's @init exception handler does.
Cheers,
~Ralph
Re: Process PINI-Record again as soon as device is reconnected Friederich, Dr. Simon via Tech-talk
Process PINI-Record again as soon as device is reconnected Dr. Simon Friederich via Tech-talk
Prev: Process PINI-Record again as soon as device is reconnected Dr. Simon Friederich via Tech-talk
Next: Re: Process PINI-Record again as soon as device is reconnected Friederich, Dr. Simon via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
