Dear Ralph,
But does @init except handle the case if the ioc is already running before a device is available? I think I've tested both (@init, PINI) and that did not help with this issue.
Best regards
Am 16. Mai 2025, 19:34, um 19:34, Ralph Lange <[email protected]> schrieb:
>On Fri, 16 May 2025 at 16:05, Dr. Simon Friederich via Tech-talk
><[email protected]> wrote:
>In most cases I use asyn + streamdevice to talk to my devices so I
>guess might be some kind of signal comming from asyn "hey, the device
>is back online, now you can (re)process your PINI-records"?
>That's what StreamDevice's @init exception handler does.
>Cheers,
>~Ralph
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
